temporal queries via WFS
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Dec 20 14:29:39 EST 2005
Tom,
I think that should work. I checked a bit the code and It should not be
too bad to integrate. You should post it as an enhancement for sure.
Later,
Kralidis,Tom [Burlington] wrote:
>Assefa,
>Thanks for the info. What about doing it like this:
>- WFS filter is sent
>- mapwfs.c checks mapfile to see if LAYER/METADATA/"ows_timefield" matches Property element
> - if yes, do a time-enabled expression
> - if no, do a literal expression as per usual
>Comments?
>..Tom
>-----Original Message-----
>From: UMN MapServer Users List on behalf of Yewondwossen Assefa
>Sent: Tue 20-Dec-05 14:00
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Cc:
>Subject: Re: [UMN_MAPSERVER-USERS] temporal queries via WFS
>Tom,
> This end up to be setting the expression as It was a litteral
>expression instead of setting it using the back tics that indicates to
>mapserver to do time comparing (`[time_field]` ge `2004-10-12`). There
>is no detection right now to see if the filer parameters are time values
>or not. Not even sure how we should detect it. If we can find a way or
>logic to indicate that the value is a time, setting the filter is pretty
>easy.
>Later,
>>Hi,
>>I'd like to do a GetFeature request, something like:
>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?service=WFS&version=1.0.0&request=GetFeature&typename=obs&filter=<Filter><PropertyIsGreaterThan><Property>datetime</Property><Literal>2002-10-30T00:00:00Z</Literal></PropertyIsGreaterThan></Filter>
>>The result should bring back two results (i.e. more recent than 2002), but returned are all the records. The data is configured for WMS Time support.
>>Is it possible to do temporal slices in MapServer WFS in this fashion?
>>..Tom
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
