Negative numbers in a Label OFFSET, how?
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 28 17:53:09 EST 2005
URL should be:
http://maps.dnr.state.mn.us/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/offset/test.map&mode=map
>>> Steve Lime <steve.lime at DNR.STATE.MN.US> 12/28/05 4:30 PM >>>
That shouldn't be the case. Offsets are applied regardless of sign. Here's a test case:
http://maps/cgi-bin/mapserv48?map=/usr/local/www/docs_maps/testing/offset/test.map&mode=map
Steve
>>> Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/28/05 1:44 PM >>>
All,
My OFFSET values are being interpreted as Positive even though they are
negative numbers.
Actually only the "y" value is doing this, the X value seems to be
working just fine.
Do I need to quote the "-" signs or something in the MAP file?
I didn't see anything in the Reference page about it.
bobb
