Controlling line thickness
Don Isgitt
djisgitt at SOUNDENERGY.COM
Fri Dec 30 11:51:24 EST 2005
Hello,
I am plotting a contour map using Mapserver; the data is in a line type
shapefile. There is a feature in the dbf that describes the line
thickness, so as to allow , say, every fifth contour to be thicker than
the others (or, for that matter, to be a different color). The contour
map is being drawn fine, but being able to "bold" certain lines would be
much better. I have not found a parameter that allows me to control line
thickness. How can I do this?
Thank you,
Don
