MINSCALE/MAXSCALE questions, cont'd
Gerry Creager N5JXS
gerry.creager at TAMU.EDU
Wed Feb 16 10:03:34 EST 2005
Thanks... bigger numbers than I expected. Image size is 700x700; width
is about 450, plus/minus a few (scalebar and markI eyeball)...
Ah! Better. Now if I can resolve the buffer issue so the labels aren't
on top of each other (make e'm sparcer)...
Stephen Woodbridge wrote:
> There is no intuitive way that I have found to relate scale to maps
> areas. I typically set up my scales using:
> 20M, 4M, 2M, 1M, 500K, 150K, 50K, 25K, 10K, 7.5K, 5K, 2K
> Or something like that. Where the image is 300 x 200 and the width in
> miles below are based on the scale bar
> 20M is VA, OH and north to all of ME or 1200 mi
> 4M is roughly MA, CT and RI or 120 mi
> 2M is roughly 60 mi
> 1M is roughly 24 mi
> 500K is roughly 8.5 mi
> 150K is roughly 2.4 mi
> 50K is roughly 1.2 mi
> etc
> This should give you an idea of what value ranges you should be looking at.
> -Steve W.
> Gerry Creager N5JXS wrote:
>> I should have included the LAYER portion of the mapfile in my last
>> message. Sorry! Here it is...
>> LAYER
>> NAME Cities
>> METADATA
>> "wfs-title" "NWS Cities Table"
>> END
>> TYPE point
>> STATUS default
>> DATA /var/www/mesonet/texas/data/ci19nv04.shp
>> DUMP true
>> LABELITEM 'name'
>> LABELCACHE on
>> # LABELMINSCALE 1000000
>> LABELMAXSCALE 5.0
>> CLASS
>> color 128 64 64
>> LABEL
>> FORCE TRUE
>> COLOR 128 64 64
>> TYPE BITMAP
>> SIZE medium
>> POSITION cr
>> OFFSET 4 7
>> BUFFER 150
>> PARTIALS TRUE
>> END
>> SYMBOL 'triangle'
>> SIZE 5
>> END
>> END
>> Gerry Creager -- gerry.creager at tamu.edu
>> Texas Mesonet -- AATLT, Texas A&M University
>> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>> Page: 979.228.0173
>> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Page: 979.228.0173
