Premature end of script headers...
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Mon Jan 3 12:39:43 EST 2005
Hello Jef,
It's important that you know what kind off premature end of scrip
headers it is, is it mapserv.exe or perhaps php? If its mapserv.exe,
then you download this program: http://www.dependencywalker.com/. Check
what file mapserv.exe is missing, in my case, it was something like
ms***.dll. Search for the file (even on the internet) en put it in the
right map.
grtz
Wouter Schaubroeck
Belgium
Wim Blanken wrote:
> Hello Jeff,
> My experience untill now is that you have to copy all dll's into the
> directory WINDOWS\SYSTEM32.
> I think that the webserver user (apache?) has no rights to load the dll's
> from your mapserver directory.
> How did you install mapserver on linux, did you get compile errors of
> some
> kind?
> Regards,
> Wim Blanken
> The Netherlands
> ----- Original Message -----
> From: "Jeff Portwine" <jdport at VERITIME.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, January 03, 2005 4:03 PM
> Subject: [UMN_MAPSERVER-USERS] Premature end of script headers...
>> I was having a lot of problems with my linux install of mapserver,
>> simply
>> trying to get the demo to run, so finally I changed my approach and
>> attempted to install mapserv on a windows xp web server (apache 2).
>> When
>> I run mapserv without any options, I get the proper response from
>> mapserv
>> but as soon as I try to make it run the demo, mapserv crashes and I get
>> "internal server error" and the following shows up in my web error logs:
>> [Mon Jan 03 09:54:11 2005] [error] [client 208.251.242.95] Premature end
>> of
>> script headers: mapserv40.exe, referer:
>> http://solo.veritime.com/workshop/
>> When I first installed mapserver, I was having the same problem even
>> when
>> I
>> ran mapserv.exe without any options. Copying all of the dll's into the
>> directory mapserv.exe was being called from fixed that... but now I get
>> this
>> as soon as I attempt to view a map. If anybody has any suggestions it
>> would be greatly appreciated, I'm really struggling to get this working
>> and
>> to learn how to use it.
>> Thanks,
>> Jeff
