Premature end of script headers...
Wim Blanken
w.blanken at GEON.NL
Mon Jan 3 13:49:51 EST 2005
Hi Jeff,
I think mpr.dll is not your problem. Look at the following thread:
http://lists.gis.umn.edu/pipermail/mapserver-users/2004-February/010300.html
I quess something else is screwing up your dll-dependencies.....but I have
no clue
which one...maybe someone else?
Regards,
Wim Blanken
The Netherlands
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, January 03, 2005 7:00 PM
Subject: Re: [UMN_MAPSERVER-USERS] Premature end of script headers...
> It is giving the error for mapserver. I actually already had tried the
> dependancywalker program and corrected the missing .dll that you
> mentioned.
> At this point, it does not show any missing .dll files. It does,
> however,
> show one .dll "red" instead of black like all of the others (mpr.dll) and
> there is a message: "Warning: At least one module has an unresolved
> import
> due to a missing export function in a delay-load dependant module." I
> really don't know what that means or if that is causing the problem, but I
> searched for a more up to date version of mpr.dll and couldn't find
> anything.
> Thanks,
> Jeff
> From: "Wouter Schaubroeck" <wouter.schaubroeck at GMAIL.COM>
> Sent: Monday, January 03, 2005 12:39 PM
>> Hello Jef,
>> It's important that you know what kind off premature end of scrip
>> headers it is, is it mapserv.exe or perhaps php? If its mapserv.exe,
>> then you download this program: http://www.dependencywalker.com/. Check
>> what file mapserv.exe is missing, in my case, it was something like
>> ms***.dll. Search for the file (even on the internet) en put it in the
>> right map.
>> grtz
>> Wouter Schaubroeck
>> Belgium
>> Wim Blanken wrote:
>>> Hello Jeff,
>>> My experience untill now is that you have to copy all dll's into the
>>> directory WINDOWS\SYSTEM32.
>>> I think that the webserver user (apache?) has no rights to load the
>>> dll's
>>> from your mapserver directory.
>>> How did you install mapserver on linux, did you get compile errors of
>>> some
>>> kind?
>>> Regards,
>>> Wim Blanken
>>> The Netherlands
>>> From: "Jeff Portwine" <jdport at VERITIME.COM>
>>> Sent: Monday, January 03, 2005 4:03 PM
>>> Subject: [UMN_MAPSERVER-USERS] Premature end of script headers...
>>>> I was having a lot of problems with my linux install of mapserver,
>>>> simply
>>>> trying to get the demo to run, so finally I changed my approach and
>>>> attempted to install mapserv on a windows xp web server (apache 2).
>>>> When
>>>> I run mapserv without any options, I get the proper response from
>>>> mapserv
>>>> but as soon as I try to make it run the demo, mapserv crashes and I get
>>>> "internal server error" and the following shows up in my web error
>>>> logs:
>>>> [Mon Jan 03 09:54:11 2005] [error] [client 208.251.242.95] Premature
>>>> end
>>>> of
>>>> script headers: mapserv40.exe, referer:
>>>> http://solo.veritime.com/workshop/
>>>> When I first installed mapserver, I was having the same problem even
>>>> when
>>>> I
>>>> ran mapserv.exe without any options. Copying all of the dll's into
>>>> the
>>>> directory mapserv.exe was being called from fixed that... but now I get
>>>> this
>>>> as soon as I attempt to view a map. If anybody has any suggestions it
>>>> would be greatly appreciated, I'm really struggling to get this
>>>> working
>>>> and
>>>> to learn how to use it.
>>>> Thanks,
>>>> Jeff
