Premature end of script headers...
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Mon Jan 3 17:06:51 EST 2005
Hi Jeff,
Did you make you're tmp directory? If you're working with apache, it
should be in you're htdocs, AND internet users must have (limited) acces
to this folder. You set this permissions by installing the IIS from win
xp and then rightclick on the tmp folder. There you chose share for web
(or something like that). There is another way, but actually, i don't
know what...
This is just a guessing, so don't shoot me if I'm wrong ;)
Grtz
Wouter Schaubroeck
Wim Blanken wrote:
> Hi Jeff,
> I think mpr.dll is not your problem. Look at the following thread:
> http://lists.gis.umn.edu/pipermail/mapserver-users/2004-February/010300.html
> I quess something else is screwing up your dll-dependencies.....but I
> have
> no clue
> which one...maybe someone else?
> Regards,
> Wim Blanken
> The Netherlands
> ----- Original Message -----
> From: "Jeff Portwine" <jdport at VERITIME.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, January 03, 2005 7:00 PM
> Subject: Re: [UMN_MAPSERVER-USERS] Premature end of script headers...
>> It is giving the error for mapserver. I actually already had tried the
>> dependancywalker program and corrected the missing .dll that you
>> mentioned.
>> At this point, it does not show any missing .dll files. It does,
>> however,
>> show one .dll "red" instead of black like all of the others
>> (mpr.dll) and
>> there is a message: "Warning: At least one module has an unresolved
>> import
>> due to a missing export function in a delay-load dependant
>> module." I
>> really don't know what that means or if that is causing the problem,
>> but I
>> searched for a more up to date version of mpr.dll and couldn't find
>> anything.
>> Thanks,
>> Jeff
>> From: "Wouter Schaubroeck" <wouter.schaubroeck at GMAIL.COM>
>> Sent: Monday, January 03, 2005 12:39 PM
>>> Hello Jef,
>>> It's important that you know what kind off premature end of scrip
>>> headers it is, is it mapserv.exe or perhaps php? If its mapserv.exe,
>>> then you download this program: http://www.dependencywalker.com/. Check
>>> what file mapserv.exe is missing, in my case, it was something like
>>> ms***.dll. Search for the file (even on the internet) en put it in the
>>> right map.
>>> grtz
>>> Wouter Schaubroeck
>>> Belgium
>>> Wim Blanken wrote:
>>>> Hello Jeff,
>>>> My experience untill now is that you have to copy all dll's into the
>>>> directory WINDOWS\SYSTEM32.
>>>> I think that the webserver user (apache?) has no rights to load the
>>>> dll's
>>>> from your mapserver directory.
>>>> How did you install mapserver on linux, did you get compile errors of
>>>> some
>>>> kind?
>>>> Regards,
>>>> Wim Blanken
>>>> The Netherlands
>>>> Sent: Monday, January 03, 2005 4:03 PM
>>>> Subject: [UMN_MAPSERVER-USERS] Premature end of script headers...
>>>>> I was having a lot of problems with my linux install of mapserver,
>>>>> simply
>>>>> trying to get the demo to run, so finally I changed my approach and
>>>>> attempted to install mapserv on a windows xp web server (apache 2).
>>>>> When
>>>>> I run mapserv without any options, I get the proper response from
>>>>> mapserv
>>>>> but as soon as I try to make it run the demo, mapserv crashes and
>>>>> I get
>>>>> "internal server error" and the following shows up in my web error
>>>>> logs:
>>>>> [Mon Jan 03 09:54:11 2005] [error] [client 208.251.242.95] Premature
>>>>> end
>>>>> of
>>>>> script headers: mapserv40.exe, referer:
>>>>> http://solo.veritime.com/workshop/
>>>>> When I first installed mapserver, I was having the same problem even
>>>>> when
>>>>> I
>>>>> ran mapserv.exe without any options. Copying all of the dll's into
>>>>> the
>>>>> directory mapserv.exe was being called from fixed that... but now
>>>>> I get
>>>>> this
>>>>> as soon as I attempt to view a map. If anybody has any
>>>>> suggestions it
>>>>> would be greatly appreciated, I'm really struggling to get this
>>>>> working
>>>>> and
>>>>> to learn how to use it.
>>>>> Thanks,
>>>>> Jeff
