Problems Displaying GeoTIFF
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Wed Jan 5 09:04:18 EST 2005
Hi Stef,
Did you install the GDAL libraries? Those are needed to use GeoTiffs
with Mapserver, you can find it here: http://gdal.maptools.org/index.html.
I hope this helps
grtz
Wouter Schaubroeck
Stefan Schwarzer wrote:
> Hi there,
> seems to be a dump question. But I tried to find the solution in older
> threats, but nothing solved my problem. So hope to find the solution
> to - I guess - a simple question here:
> I need to display three-channel GeoTiffs with PHP-Mapscript. But it
> doesn't display anything. Is it the IMAGEMODE? Or perhaps a
> compilation issue (I use the Win-Binaries)? Any advice?
> Thanks a lot,
> Stef
> _______________________________________
> *Stefan Schwarzer
> * GIS & Data Management
> UNEP/DEWA/GRID-Geneva
> Chemin des Anemones 11
> CH - 1219 Chatelaine
> Switzerland
> Tel: (+41) 22.917.83.49
> Fax: (+41) 22.917.80.29
> Internet: http://geodata.grid.unep.ch/
