Problems Displaying GeoTIFF
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Jan 5 09:30:50 EST 2005
On Wed, 5 Jan 2005 14:39:34 +0100, Stefan Schwarzer
<stefan.schwarzer at grid.unep.ch> wrote:
> Hi there,
> seems to be a dump question. But I tried to find the solution in older
> threats, but nothing solved my problem. So hope to find the solution to
> - I guess - a simple question here:
> I need to display three-channel GeoTiffs with PHP-Mapscript. But it
> doesn't display anything. Is it the IMAGEMODE? Or perhaps a compilation
> issue (I use the Win-Binaries)? Any advice?
Stef,
If you aren't seeing anything then the problem is likely not
IMAGEMODE. But you will need to show us what you are
doing if you want meaningful feedback. Do you have 8bit
rasters working? Normally if you have pseudocolored input
rasters working then 24bit should work directly though you might
find you need to tweak things to get good quality output.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
