Problems Displaying GeoTIFF
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Wed Jan 5 09:43:27 EST 2005
Thanks for the inputs. Here are some more details:
- I am working with an 8 bit GeoTIFF.
- I tried it on a Windows2000 machine, as well now on a Linux.
- Don't know if the GDAL libs have been installed on the Linux machine
-- I guess so. How can I verify it? On the Win I just have installed
the OpenEV_FW tool, so I guess it should have installed the necessary
libs as well, right?
- Anyway, are there other libs necessary if I display GeoTIFFs and
"normal" TIFFs with a Worldfile? Cause that works.
What else can I give you as information?
Stef
> Hi Stef,
> Did you install the GDAL libraries? Those are needed to use GeoTiffs
> with Mapserver, you can find it here:
> http://gdal.maptools.org/index.html.
> I hope this helps
> grtz
> Wouter Schaubroeck
> Stefan Schwarzer wrote:
>> Hi there,
>> seems to be a dump question. But I tried to find the solution in older
>> threats, but nothing solved my problem. So hope to find the solution
>> to - I guess - a simple question here:
>> I need to display three-channel GeoTiffs with PHP-Mapscript. But it
>> doesn't display anything. Is it the IMAGEMODE? Or perhaps a
>> compilation issue (I use the Win-Binaries)? Any advice?
>> Thanks a lot,
>> Stef
>> _______________________________________
>> *Stefan Schwarzer
>> * GIS & Data Management
>> UNEP/DEWA/GRID-Geneva
>> Chemin des Anemones 11
>> CH - 1219 Chatelaine
>> Switzerland
>> Tel: (+41) 22.917.83.49
>> Fax: (+41) 22.917.80.29
>> Internet: http://geodata.grid.unep.ch/
Stefan Schwarzer
Switzerland
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050105/b33938de/attachment.bin
