Fwd: [UMN_MAPSERVER-USERS] NetCDF via OpenDAP/DODS into mapserv
Frank Ehlers
LuckyEddie at GMX.NET
Fri Jan 7 12:57:10 EST 2005
Hi again!
I am sorry for reposting my last email. Is the question too stupid?
Or is there an example I have not found?
Please, give me some hints.
Thank you very much in advance,
Frank
--- Weitergeleitete Nachricht / Forwarded Message ---
Date: Thu, 30 Dec 2004 15:42:51 -0600
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] NetCDF via OpenDAP/DODS into mapserv
Hi!
I have tried to display the content of a NetCDF .nc file with MAPSERVER.
The DODS seems to work: If I am using ogrinfo with appropriate parameters
on DODS:http//..allnetworkstuff..file.nc?Depth[1,1,10][1,1,1]
(or was it Depth[1:1:10][1:1:10] ? Sorry, I cannot remember at the moment)
I see the following kind of output for the 10 items I requested:
lat .... some_value_lat
lon .... some_value_lon
Depth .... some_value_depth
POINT (some_value_lon some_value_lat)
Now, my ideas was to display the depth chart via mapserver.
The only examples I found have lines of code like these:
CONNECTION ....(like the input for ogrinfo, but with 1000 times 1000 values)
TYPE POINT
DATA "Depth"
CLASS
COLOR 255 0 0
END
All I see in the web browser (after putting the correct latlong values into
the map file to view the area the latlong values specify in the NetCDF
file) is then a rectangular area filled with red points. That makes me
believe that in principle the connection, the .nc NetCDF file and the map
file are ok.
My QUESTION:
How can I plot an image (color coded depth values) with this method?
It would be great if anyone could help me here(e.g. some example code)!
Best regards,
Frank
+++ GMX - die erste Adresse für Mail, Message, More +++
1 GB Mailbox bereits in GMX FreeMail http://www.gmx.net/de/go/mail
