Labels Not Displayed
Dan Phillips
danp at AMERICANCLEARINGHOUSE.COM
Fri Jan 7 14:22:09 EST 2005
I'm new to Mapserver and am having trouble getting labels to display on my
map. Everything works fine... no errors, just no labels. The text from my
map file is below. Any ideas on what might be wrong?
Thank you,
Dan
IMAGETYPE jpeg
SIZE 800 600
SYMBOLSET "c:/ms4w/etc/symbols_mapinfo.sym"
FONTSET "C:/ms4w/Apache/htdocs/fonts/fonts.list"
STATUS ON
EXTENT 610004 4227375 636669 4247374
UNITS METERS
SHAPEPATH "/test/"
IMAGECOLOR 255 255 255
WEB
TEMPLATE "C:/ms4w/Apache/htdocs/test/40242.html"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL '/ms_tmp/'
END
PROJECTION
"init=epsg:26916"
END
LAYER
NAME "KYJeffW"
Type LINE
PROJECTION
"init=epsg:4326"
END
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "R:/STREETS/KY/WATER.TAB"
STYLEITEM "Auto"
CLASS
NAME "2"
END
END
LAYER
NAME "Streets"
Type LINE
PROJECTION
"init=epsg:4326"
END
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "R:/STREETS/KY/STREETS.TAB"
STYLEITEM "Auto"
LABELITEM "name"
LABELMAXSCALE 30000
CLASS
Name 'road_labels'
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 7
MINSIZE 4
MAXSIZE 256
POSITION CC
ANGLE AUTO
BUFFER 2
MINDISTANCE 150
MINFEATURESIZE 20
COLOR 100 50 0
SHADOWCOLOR 0 0 0
SHADOWSIZE 0 0
PARTIALS FALSE
END
END # Class
END
END
