Installation Problem - error while loading shared libraries
{Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri Jan 7 15:11:18 EST 2005
you can use ldd command to see what shared libraries are mapserv depend
on:
ldd mapserv
check the directories and files.
You may add some directories to the /etc/ld.so.conf file.
Don't forget to reread the config file with
ldconfig
bye
Zoltan
On Fri, 7 Jan 2005, Craig Nakamoto wrote:
> Hello,
> I am a new user to MapServer and all my test development has occurred on
> my local Windows machine. Now I want to create a UNIX MapServer
> environment and I am using Red Hat Enterprise v3.
> I have reached the point of compiling MapServer itself and I use the
> following configure options:
> sudo ./configure --with-proj --with-php=/usr/include/php
> Everything seems to work fine, and 'configure' locates all the required,
> and my requested, optional components (many of which I compiled instead
> of using RPMs).
> Then I do a 'make' and it looks like it works but when I try to execute
> the mapserv binary I get:
> [claero at cw2000 mapserver-4.4.1]$ ./mapserv
> ./mapserv: error while loading shared libraries: libgd.so.2: cannot open
> shared object file: No such file or directory
> The documentation says that 'something has gone horribly wrong' and to
> email this group. Any help would be greatly appreciated.
> In the configure output here is the excerpt regarding GD:
> configure: checking for GD 2.0.12 or higher...
> checking for gdImageSetAntiAliased in -lgd... yes
> checking for gdImageSetAntiAliased in -lgd... (cached) yes
> using libgd 2.0.12 (or higher) from system libs
> (-L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz ).
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... yes
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageGifPtr in -lgd... yes
> checking for gdFontGetTiny in -lgd... yes
> using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS) from system
> libs.
> Thanks!
> Craig
> ______________________________________
> Craig Nakamoto, Senior Consultant
> IT Consulting and Services for Your Business
> Claero Systems | www.claero.com
> (403) 242-2667 x105 (phone)
> (403) 261-0718 (fax)
