Assign special dbf to shapefile
Sean Gillies
sgillies at FRII.COM
Fri Jan 7 15:00:55 EST 2005
Steve,
Moving to PostGIS wouldn't be as hard as you think. There are many of
us who will be glad to help you out. Another better possibility is
trying to light a fire under the MapServer/MySQL developer so that you
can move your shapes into MySQL. I'm not even talking about a
PostGIS-ish library for MySQL, just putting features in as a blob that
can be extracted and converted to MapServer shapes for rendering, and
spatial indexes.
Sean
On Jan 7, 2005, at 12:44 PM, Stephen Woodbridge wrote:
> The issue is that you can not do joins to classify data when drawing
> maps if you use shapefiles. JOIN works fine with queries.
> I have all the tiger data in shapefile (16 GB of data) and all of the
> Census Summary File 1 and 3 data in MySQL (101 GB, plus a lot more for
> indexes). I would like to draw thematic maps of the US based on these
> datasets. Moving all this data to PostGIS, is possible but a huge task,
> not to mention I would have to learn a new DB and how to administer it.
> I will probably end up doing this at some point when the need is
> higher.
> Meanwhile, this is basically what others are trying to do also. It is
> just a HUGE step to move from shapefiles and MySQL to managing
> everything in PostGIS.
> Still hoping Steve Lime will take pity on me,
> but not holding my breath.
> -Steve
> Ken Lord wrote:
>> This definately calls for PostGIS, and I'm sure it would process the
>> request much faster.
>> But,
>> Why not use the join object in mapserver?
>> http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#join
>> Or is this join system, that was broken i think after mapserver 3.4,
>> still not functional? ... and if it is still not functional why have
>> the instructions remained in the current documentation for the last 2
>> years+ ... since at least mapserver 3.6?
>> There is another option:
>> Don't join the data on-the-fly. Instead when the user queries the
>> airport, have a link parsed in the query results that when followed
>> displays the attribute data you want based on the query results
>> returned. ... A little ASP works wonders here to take a mapserver
>> query result and query another database with it.
>> Cheers,
>> Ken
>> On Fri, 7 Jan 2005 10:22:02 -0500, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>> The only way that I know of to do runtime joins in mapserver is to
>>> use
>>> PostGIS. You might be able to do something with gdal, but I think it
>>> is
>>> very slow. I have requested support for runtime shapefile joins to
>>> either DBF or MySQL multiple times and nothing has happened in that
>>> direction. Basically, it would be very slow because for each object
>>> in
>>> the shapefile, you would have to scan the whole DBF file, because
>>> there
>>> are no indexes support for DBF files, or the developers would have to
>>> build DBF indexing support into mapserver. For Mysql, you could index
>>> the columns, but you would still need to make a separate query for
>>> every
>>> object in the shapefile.
>>> In PostGIS, since you have all the data in the database to start with
>>> you can make one query for the layer and do the join in that query,
>>> then
>>> you only have to fetch back the objects to render.
>>> -Steve W.
>>> Holger Floerke wrote:
>>>> Hi Jacob,
>>>>> Why would you not want to join them?
>>>> If the information I would like to present is evaluated at runtime,
>>>> I have
>>>> to produce a full set of ".shp", ".dbf", "sbx", "sbn", and ".shx"
>>>> files. The
>>>> shapes always stays the same, but the data is extracted from a
>>>> database on a
>>>> user's query. I would like to save space by not copying the shape
>>>> information every time.
>>>>> unless if you created a join on a dbf, and accessed it separately.
>>>> Is it possible to join external data sources (one or more dbf-files
>>>> or
>>>> oci-sources) to shape files at runtime with the mapserver-api?
>>>> HolgeR
>>>> Jacob Delfos schrieb:
>>>>> Holger,
>>>>> Correct me if I'm wrong, but that would be redefining the
>>>>> definition of
>>>>> a shapefile. As far as I know, a "shapefile" is not the .shp file,
>>>>> but
>>>>> the collection of ".shp", ".dbf", "sbx", "sbn", and ".shx" files. I
>>>>> think you'd have to seriously hack the source of mapserver to do
>>>>> that,
>>>>> Why would you not want to join them? If you have access to MS
>>>>> Excel, it
>>>>> would be as simple as copying a column across. No doubt other
>>>>> software
>>>>> can do the same thing. You would have access to both attributes in
>>>>> one
>>>>> shapefile. What is the actual problem that causes you not to want
>>>>> to
>>>>> have two shapefiles, and not to want to join the attributes?
>>>>> regards,
>>>>> Jacob
>>>>> -----Original Message-----
>>>>> From: UMN MapServer Users List
>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>> Sent: 1/7/2005 9:03 PM
>>>>> Subject: [UMN_MAPSERVER-USERS] Assign special dbf to shapefile
>>>>> Hi all,
>>>>> am I able to assign a special dbf-file to a shape file? For example
>>>>> rendering the 'airports.shp', but using data from
>>>>> 'airports_passengers.dbf'
>>>>> and not from 'airports.dbf' (ensuring the correct order for the
>>>>> shape-information-mapping). Or another example, render some area
>>>>> shapes
>>>>> on
>>>>> the one hand with popuplation data and on the other hand with
>>>>> unemployment
>>>>> data without integrating both data sets into the dbf of the shape
>>>>> file
>>>>> and
>>>>> without producing two different shape-files. I use php-mapscript
>>>>> and
>>>>> mapserver 4.4.
>>>>> HolgeR
