Assign special dbf to shapefile
Norman Vine
nhv at CAPE.COM
Fri Jan 7 15:11:54 EST 2005
Stephen Woodbridge writes:
> The issue is that you can not do joins to classify data when drawing
> maps if you use shapefiles. JOIN works fine with queries.
What would be nice to have is a 'virtual' query that would render
a 'virtual' data set.
We have the GDAL ".vrt" data mechanism what is missing is the
equivalant 'query' mechanism to create these dynamically from
something only the developer of the site knows about.
Of course there is always mapscript which allows you to do
this and *much* more :-)
Cheers
Norman
