Labels Not Displayed {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri Jan 7 17:56:05 EST 2005
Try to change TYPE LINE to TYPE ANNOTATION.
Another notice, why do you use STYLEITEM AUTO if you specify
style for the labels?
Bye
Zoltan
On Fri, 7 Jan 2005, Dan Phillips wrote:
> I'm new to Mapserver and am having trouble getting labels to display on my
> map. Everything works fine... no errors, just no labels. The text from my
> map file is below. Any ideas on what might be wrong?
> Thank you,
> Dan
> IMAGETYPE jpeg
> SIZE 800 600
> SYMBOLSET "c:/ms4w/etc/symbols_mapinfo.sym"
> FONTSET "C:/ms4w/Apache/htdocs/fonts/fonts.list"
> STATUS ON
> EXTENT 610004 4227375 636669 4247374
> UNITS METERS
> SHAPEPATH "/test/"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE "C:/ms4w/Apache/htdocs/test/40242.html"
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL '/ms_tmp/'
> END
> PROJECTION
> "init=epsg:26916"
> END
> LAYER
> NAME "KYJeffW"
> Type LINE
> PROJECTION
> "init=epsg:4326"
> END
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "R:/STREETS/KY/WATER.TAB"
> STYLEITEM "Auto"
> CLASS
> NAME "2"
> END
> END
> LAYER
> NAME "Streets"
> Type LINE
> PROJECTION
> "init=epsg:4326"
> END
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "R:/STREETS/KY/STREETS.TAB"
> STYLEITEM "Auto"
> LABELITEM "name"
> LABELMAXSCALE 30000
> CLASS
> Name 'road_labels'
> LABEL
> TYPE TRUETYPE
> FONT "arial"
> SIZE 7
> MINSIZE 4
> MAXSIZE 256
> POSITION CC
> ANGLE AUTO
> BUFFER 2
> MINDISTANCE 150
> MINFEATURESIZE 20
> COLOR 100 50 0
> SHADOWCOLOR 0 0 0
> SHADOWSIZE 0 0
> PARTIALS FALSE
> END
> END # Class
> END
> END
