NetCDF via OpenDAP/DODS into mapserv
Frank Warmerdam
fwarmerdam at GMAIL.COM
Sat Jan 8 13:06:52 EST 2005
On Thu, 30 Dec 2004 15:42:51 -0600, Frank Ehlers <LuckyEddie at gmx.net> wrote:
> All I see in the web browser (after putting the correct latlong values into
> the map file to view the area the latlong values specify in the NetCDF
> file) is then a rectangular area filled with red points. That makes me
> believe that in principle the connection, the .nc NetCDF file and the map
> file are ok.
Eddie,
Cool, I think you are past the hard part at least.
> My QUESTION:
> How can I plot an image (color coded depth values) with this method?
> It would be great if anyone could help me here(e.g. some example code)!
You will need to make a CLASS declaration for each
color you want in your color ramp, classified on the basis
of your depth variable. Lots of CLASSes like this:
CLASS
NAME "10 - 20"
EXPRESSION "([DEPTH] > 10 and [DEPTH] < 20)"
COLOR 0 0 255
END
Unfortunately, there isn't really any mechanism in
MapServer to color features based on a colorbar using
some attribute scaled to the color bar. Hopefully that can
be added at some point.
PS. Don't exactly trust what I have typed. I haven't tried
this too recently. But it should give you an idea and you can
dig around in the mapfile reference and other examples for
additional details.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
