USGS URBAN 133 Metadata ?
Matt Brown
mbrown at AL1CALL.COM
Mon Jan 10 14:48:58 EST 2005
http://edcw2ks51.cr.usgs.gov/servlet/com.esri.wms.Esrimap?REQUEST=Getcapabil
ities&servicename=133urban
but you could also just update the names to the more recent service, this
works also and is much easier since you don't have to search the extents:
LAYER
NAME "URBANAREABHAM"
TYPE RASTER
STATUS OFF
MAXSCALE 24000
MINSCALE 800
CONNECTION
"http://gisdata.usgs.gov/servlet/com.esri.wms.Esrimap?WMTVER=1.1.1&ServiceNa
me=USGS_EDC_Ortho_133Urban&layers=Birmingham01&format=png"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_title" "Birmingham01"
END
END
you should be able to replace Birmingham01 with Atlanta01, 02, 03, or 04 and
it should work fine.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Shanton, James A
Sent: Monday, January 10, 2005 1:26 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] USGS URBAN 133 Metadata ?
I noticed the Numeric Names, Is there a place I can find those ?
Thanks !
Jim
Sent: Monday, January 10, 2005 2:20 PM
To: Shanton, James A; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] USGS URBAN 133 Metadata ?
James,
here is part of a mapfile with the 133Urban that I have working:
LAYER
TYPE RASTER
STATUS OFF
MAXSCALE 24000
MINSCALE 800
CONNECTION
"http://edcw2ks51.cr.usgs.gov/servlet/com.esri.wms.Esrimap?WMTVER=1.1.1&Serv
iceName=133urban&layers=UA_ORTHO_230_01&format=png"
CONNECTIONTYPE WMS
METADATA
"wms_title" "UA_ORTHO_230_01"
END
END
this is for birmingham and I haven't updated the address so I am still using
an older address for the wms server and the numeric names instead of the
current names(ie, birmingham01).
hope this helps,
Matt
Sent: Monday, January 10, 2005 12:16 PM
Thanks for the information on the getcapabilities function. I saw all the
Layer names in the XML document and tried to call those but did not have any
luck.
LAYER
NAME colorWMS
METADATA
"wms_title" "USGS_EDC_Ortho_133Urban"
"wms_latlonboundingbox" "-178.217598362365 18.9247817993164
-66.9692710360024 71.4062353532712"
END
OFFSITE 255 255 255
STATUS DEFAULT
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?VERSION=1.1.0&SERVICE=
OGC:WMS&FORMAT=jpeg&LAYERS=Atlanta02&REQUEST=getmap&styles="
PROJECTION
"init=epsg:4326"
END
END
Sent: Monday, January 10, 2005 10:14 AM
Shanton, James A writes:
> Sort of like this ?
No
I posted the location of where to get the metadata not
the WMS CONNECTION string, per your request :-)
If you are not familiar with a WMS Capabilities REQUEST see
http://mapserver.gis.umn.edu/doc40/wms-server-howto.html
and specifically
http://www.opengis.org/docs/01-047r2.pdf
Cheers
Norman
> > Is there a location that would give me the
> > Metadata for the Urban 133 Orthophotoimagery ?
> > I found these samples out there, but I can't find the Metadata for the
> > Atlanta area extents, or other Covered areas in the US.
> > "wms_title"
> > "wms_extent"
> > Thanks !
> Try this < all one URL >
> Norman
http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?WMTVER=1.1.0&LAYERS=Alb
> uquerque01,Allentown01,Amarillo01,Amarillo02,Anchorage01
,Atlanta01,Atlanta02,Atlanta03,Atlanta04,Atlanta05,Austin01,Baltimore01,Bato
> nRouge01,Birmingham01,Bismarck01,Boston01,Boston02,Carso
n01,Charlotte01,Charlotte02,Chattanooga01,Chicago01,Chicago02,Chicago03,Chic
> ago04,Chicago05,Chicago06,Chicago07,Chicago08,Chicago09,
Cincinnati01,Cleveland01,ColoradoSprings01,Columbus01,Dallas01,Dallas02,Dall
> as03,Dallas04,Denver01,Denver02,Denver03,Detroit01,Detro
it02,Detroit03,El_Paso01,Fresno01,FtWayne01,Glynncnty,Harrisburg01,Houston01
> ,Houston02,Houston03,Houston04,Houston05,Houston06,Hunts
ville01,Jackson01,Jacksonville01,KansasCity01,Knoxville01,Knoxville02,Knoxvi
> lle03,Laglendale01,Laglendale02,LasVegas01,Lexington01,L
incoln01,Louisville01,Lubbock01,Lubbock02,Miami01,Minneapolis01,Mobile01,Mod
> esto01,Montgomery01,Nashville01,Newark01,Newark02,Newark
03,Newark04,Newark05,Newark06,NewOrleans01,Oklahomacity01,Orlando01,Philadel
> phia01,Phoenix01,Portland01,Providence01,Raleigh01,Reno0
1,Riverside_Sanbernadino01,Sacramento01,Sacramento02,Sacramento03,SaltLakeCi
> ty01,SanDiego01,SanFrancisco01,Savannah01,SEA_ISLAND_3,S
EA_ISLAND_6,Seattle01,Seattle02,Seattle03,Seattle04,Seattle05,Shreveport01,S
> pringfield01,St_Louis01,Stockton01,Stockton02,Tampa01,Ta
mpa02,Topeka01,Trenton01,Tucson01,Washington01,Washington02,Worcester01,Worc
> ester02&FORMAT=PNG&BGCOLOR=0xFFFFFF&TRANSPARENT=true&SRS
=EPSG:4326&SERVICE=WMS&STYLES=&SERVICENAME=USGS_EDC_Ortho_133Urban&REQUEST=c
> apabilities
