TIFF displays and displays not
Ed McNierney
ed at TOPOZONE.COM
Thu Jan 13 12:08:53 EST 2005
Stef -
If I recall correctly, the INPUT=TIFF support reads GeoTIFF but not TFW
world files. Exporting the file as a GeoTIF would then fix this
problem, consistent with your observation. I'm not sure my memory is
correct, but the "built-in" TIFF support is now deprecated and you
really should remove it - GDAL will provide much better TIFF support for
you.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Stefan Schwarzer
Sent: Thursday, January 13, 2005 5:07 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] TIFF displays and displays not
Thanks to everyone for the feedback.
It seems to be a problem on the image side. I don't understand why, but
although it displays nicely in ArcView and Photoshop, the screen keeps
blank with Mapserver. (I had the impression that ArcExplorer-Java for
Mac didn't display it either.) But when I exported the TIF in ERDAS as
GeoTIF and loaded it into the app it worked.
Stef
On Thu, 13 Jan 2005, Stefan Schwarzer wrote:
Ed,
thanks for that.
Still, I can't see the reason for that. I have two TIFF
images, which
seem to be perfectly similar. I have saved them both
from Photoshop. So
no GeoTIIFF, only normal TIFF.
How do I get the "mapserv -v" on a Windows machine?
Change directory to your cgi-bin and type
mapserv.exe -v
The Linux machine is giving me this:
MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Recently I had trouble on Linux, having both native INPUT=TIFF
and
INPUT=GDAL. The gdal tiff support is more powerful then mapserv
native
solution so configure mapserverver --without-tiff and
--with-gdal.
I check my windows mapserv.exe which I downloaded in a binary
pachage, and
no INPUT=TIFF support involved.
Bye
Zoltan
Stefan -
The first thing I'd do is run "mapserv -v" on
each machine and look
for configuration differences in your two
MapServer installations.
Also, check whether both are GeoTIFFs.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
On Behalf Of Stefan Schwarzer
Sent: Wednesday, January 12, 2005 8:21 AM
Subject: [UMN_MAPSERVER-USERS] TIFF displays and
displays not
gush, what a strange thing. I have to TIFFs with
a worldfile each.
Using PHP/MapScript, on my windows machine, both
display nicely. On
our Linux machine however, only one of the two
displays. When I select
the other, white space... Nothing.
I added one of the TIFFs only now, the other
already a couple of days
ago. Sure, this can't be the reason. But ....
Actually, I have no
idea. They are both 8 bit, and RGB color mode.
Any idea whatsoever? Thanks for letting me know.
I am really stuck...
Stef
_______________________________________
Stefan Schwarzer
GIS & Data Management
UNEP/DEWA/GRID-Geneva
Chemin des Anemones 11
CH - 1219 Chatelaine
Switzerland
Tel: (+41) 22.917.83.49
Fax: (+41) 22.917.80.29
Internet: http://geodata.grid.unep.ch/
Stefan Schwarzer
Switzerland
Stefan Schwarzer
Switzerland
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050113/acc66665/attachment.html
