catching an error with php-mapscript
Steffen Köhler
skoehler at BUSCHJENA.DE
Fri Jan 14 03:22:48 EST 2005
Hello php-mapscript users,
I have an tool to generate map-files. This map-file have sometimes two
cases of errors.
The first kind (syntactic errors) can be found with analysing the
$error->code variable after running $map=ms_newMapObj(filename).
For the second kind (semantic errors, for example an forgotten "using
srid=-1" for an table not registered in geometry_columns) I hope I can
catch the error in the same way after the method $map->draw().
But this results in an segmentation fault (command line) or an internal
server error (browser), but not all the time, sometimes it works :-(
<snip example php-mapscript for the second case>
<?php
dl('php_mapscript.so');
error_reporting(0);
$map=ms_newMapObj('mapdata/MAP_13520.map');
ms_resetErrorList();
$image=$map->draw();
$error=ms_getErrorObj();
while ($error && $error->code!=MS_NOERR)
printf(" routine %s: %s\n",$error->routine,$error->message);
$error=$error->next();
</snip>
This will produce the following output starting with php tt.php. I see the
error is correctly catched in $error.
<output>
Content-type: text/html
X-Powered-By: PHP/4.3.3
routine msDrawMap(): Failed to draw layer named 'Knoten'.
Speicherzugriffsfehler
</output>
How can I catch the error generated by php-mapscript.
yours sincerely
Steffen Köhler
3Kon GmbH Informationstechnologie
Auftragsentwicklung
Fregestrasse 6/8
D-07747 Jena
Tel.: +49 3641/30 38-34
Fax.: +49 3641/30 38-20
www.buschjena.de
