Labels in two renderings of the same map ? {Scanned} {Scanned}
    Siki Zoltan
    siki at AGT.BME.HU
    Sun Jan 16 12:06:34 PST 2005
Do you use SYMBOLSCALE option for your labels? (e.g. Do you have
scaleable labels?) If so, than I think there is a minimal label size
for mapserver to render. It is no sense to render labels of 2 pixels.
Bye
Zoltan
On Sun, 16 Jan 2005, Lars V. Nielsen (GisPro) wrote:
> I've been asked to generate a map with an insert, i.e. adding a small area with a larger scale in the corner of the map.
> I've accomplished it by performing two renderings of the same map, the second rendering after setting a smaller width/height and a
> fixed extent, and using GD2 to merge the two images appropriately. This works perfectly.
> However, I've sofar been unable to get labels to display in the small insert image. They show up perfectly in the main/large image.
> I don't turn any layers on/off between the two renderings, and I don't have any label min/max scale settings in place for this
> labelling layer (which btw. is an OVF layer).
> I suspect that it's an issue connected with the label cache. I've tried to add LABELCACHE OFF to the labelling layer and remove the
> commands $map->drawLabelCache() from my code, but it makes no difference at all: the labels only (and always!) appear in the main
> window.
> If anyone has come up with a way to control labels in two map renderings, I'll be delighted to know.
> Best regards/Med venlig hilsen
> Lars V. Nielsen
> GisPro, Denmark
> http://www.gispro.dk/
More information about the MapServer-users
