Display JPEG and TIF {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sun Jan 16 18:18:30 EST 2005
To display truecolor tiff or jpeg you must have INPUT=GDAL.
There must be some trouble with your gdal installation.
I see the --with-gdal in your configure but no INPUT=GDAL in
the mapserv -v.
Try to configure and make mapserv again and check all the massages,
you had better to turn off mapserv native tiff support --without-tif.
Bye
Zoltan
On Sun, 16 Jan 2005, Juan Baron wrote:
> I have installed the following:
> 1)freetype
> 2)zlib
> 3)libpng
> 4)jpegv6
> 5)gd
> 6)proj
> 7)curl
> 8)tiff
> 9)geotiff
> 10)pdf
> 11)gdal
> 12)libungif
> 13)ming
> 14)libiconv
> 15)mapserver
> I install mapserver in the following way:
> ./configure --with-proj --with-ogr --with-gdal --with-postgis --with-ming -
> -with-wfs --with-wmsclient
> make
> When I execute "./mapserv -v", the result is:
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=SHAPEFILE
> but when I am trying to show some images jpeg or tif using a layer raster,
> it leaves me the following error:
> For the jpeg image: drawJPEG(): Unable to access file. Only grayscale
> JPEG images are supported.
> For the tif image: Image handling error. Only colormapped and grayscale
> Why??
