Display JPEG and TIF
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Jan 17 11:42:24 EST 2005
> I install mapserver in the following way:
> ./configure --with-proj --with-ogr --with-gdal --with-postgis --with-ming -
> -with-wfs --with-wmsclient
> make
> When I execute "./mapserv -v", the result is:
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=SHAPEFILE
> but when I am trying to show some images jpeg or tif using a layer raster,
> it leaves me the following error:
> For the jpeg image: drawJPEG(): Unable to access file. Only grayscale
> JPEG images are supported.
> For the tif image: Image handling error. Only colormapped and grayscale
> Why??
Juan,
For one reason or another the mapserver you ran does not include
GDAL support. Either you weren't really running the version you just
built, or the configuration of GDAL support did not work. I would suggest
you check into both issues.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
