Compilation Error on 64 bit Fedora Core 3
Gerry Creager N5JXS
gerry.creager at TAMU.EDU
Mon Jan 17 19:35:56 EST 2005
Having fought and lost some significant battles with FC3 and 64-bit
Opteron compiles (and SuSE, for that matter!), I'd suggest you consider
compiling in 32-bit compatibility mode and see how it performs. You're
not likely to see too many benefits on this code from the 64-bit compilers.
I can add this to my list of things to investigate over the next week on
my Opteron test system, but it's not likely to get to the top of the
heap real soon.
gerry
Tony Baylis wrote:
> We are trying to upgrade our Mapserver app from 3.6.6 to the latest on a new
> 64 bit machine using Fedora Core 3.
> After trying to install from .src.rpm and encountering issues related to
> 64bit, I have started again using .tar.gz files for all packages except
> those that can be installed or updated using yum, ie devel packages etc.
> The following ./configure command was used and succeeded:
> ./configure --with-jpeg --with-php=/usr/include/php/main
> --with-php-regex-dir=/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex
> --with-gdal --with-png --with-wmsclient --with-libwww --without-tiff
> --with-geos --with-postgis --with-freetype --enable-force-freetype1
> --enable-runpath
> BUT compilation (make -d) fails giving the following final output:
> Finished prerequisites of target file `maptemplate.o'.
> Must remake target `maptemplate.o'.
> gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL
> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_GEOS
> -DUSE_ICONV -DUSE_PHP_REGEX
> -I/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex/.. -DUSE_POSTGIS
> -I/usr/include -I/usr/local/include -I/usr/include -I
> maptemplate.c -o maptemplate.o
> Putting child 0x00547bd0 (maptemplate.o) PID 5464 on the chain.
> Live child 0x00547bd0 (maptemplate.o) PID 5464
> gcc: no input files
> Got a SIGCHLD; 1 unreaped children.
> Reaping losing child 0x00547bd0 PID 5464
> make: *** [maptemplate.o] Error 1
> Removing child 0x00547bd0 PID 5464 from chain.
> Is this a link problem or am I way off the mark?
> Any assistance would be greatly appreciated.
> Tony
> www.bundaberg.qld.gov.au
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
