Compilation Error on 64 bit Fedora Core 3
Tony Baylis
tonyb at BUNDABERG.QLD.GOV.AU
Mon Jan 17 19:42:24 EST 2005
Thanks Gerry,
I am using dual opterons on this machine so will go with your suggestion,
although I will keep trying for just a little longer and post a solution if
one is found.
Tony
On Tuesday 18 January 2005 10:35, Gerry Creager N5JXS wrote:
> Having fought and lost some significant battles with FC3 and 64-bit
> Opteron compiles (and SuSE, for that matter!), I'd suggest you consider
> compiling in 32-bit compatibility mode and see how it performs. You're
> not likely to see too many benefits on this code from the 64-bit compilers.
> I can add this to my list of things to investigate over the next week on
> my Opteron test system, but it's not likely to get to the top of the
> heap real soon.
> gerry
> Tony Baylis wrote:
> > We are trying to upgrade our Mapserver app from 3.6.6 to the latest on a
> > new 64 bit machine using Fedora Core 3.
> > After trying to install from .src.rpm and encountering issues related to
> > 64bit, I have started again using .tar.gz files for all packages except
> > those that can be installed or updated using yum, ie devel packages etc.
> > The following ./configure command was used and succeeded:
> > ./configure --with-jpeg --with-php=/usr/include/php/main
> > --with-php-regex-dir=/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex
> > --with-gdal --with-png --with-wmsclient --with-libwww --without-tiff
> > --with-geos --with-postgis --with-freetype --enable-force-freetype1
> > --enable-runpath
> > BUT compilation (make -d) fails giving the following final output:
> > Finished prerequisites of target file `maptemplate.o'.
> > Must remake target `maptemplate.o'.
> > gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL
> > -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> > -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_GEOS
> > -DUSE_ICONV -DUSE_PHP_REGEX
> > -I/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex/.. -DUSE_POSTGIS
> > -I/usr/include -I/usr/local/include -I/usr/include -I
> > maptemplate.c -o maptemplate.o
> > Putting child 0x00547bd0 (maptemplate.o) PID 5464 on the chain.
> > Live child 0x00547bd0 (maptemplate.o) PID 5464
> > gcc: no input files
> > Got a SIGCHLD; 1 unreaped children.
> > Reaping losing child 0x00547bd0 PID 5464
> > make: *** [maptemplate.o] Error 1
> > Removing child 0x00547bd0 PID 5464 from chain.
> > Is this a link problem or am I way off the mark?
> > Any assistance would be greatly appreciated.
> > Tony
> > www.bundaberg.qld.gov.au
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
> Page: 979.228.0173
> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Anthony Baylis
GIS Officer
Bundaberg City Council
ph 07 4153 9926
fax 07 4153 9238
e tonyb at bundaberg.qld.gov.au
web www.bundaberg.qld.gov.au
