Compilation Error on 64 bit Fedora Core 3
Colin McGuigan
cmcguigan at EARTHCOMBER.COM
Tue Jan 18 09:58:02 EST 2005
Tony Baylis wrote:
> We are trying to upgrade our Mapserver app from 3.6.6 to the latest
on a new
> 64 bit machine using Fedora Core 3.
> After trying to install from .src.rpm and encountering issues related to
> 64bit, I have started again using .tar.gz files for all packages except
> those that can be installed or updated using yum, ie devel packages etc.
> The following ./configure command was used and succeeded:
> ./configure --with-jpeg --with-php=/usr/include/php/main
> --with-php-regex-dir=/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex
> --with-gdal --with-png --with-wmsclient --with-libwww --without-tiff
> --with-geos --with-postgis --with-freetype --enable-force-freetype1
> --enable-runpath
> BUT compilation (make -d) fails giving the following final output:
> Finished prerequisites of target file `maptemplate.o'.
> Must remake target `maptemplate.o'.
> gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL
> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_GEOS
> -DUSE_ICONV -DUSE_PHP_REGEX
> -I/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex/.. -DUSE_POSTGIS
> -I/usr/include -I/usr/local/include -I/usr/include -I
> maptemplate.c -o maptemplate.o
> Putting child 0x00547bd0 (maptemplate.o) PID 5464 on the chain.
> Live child 0x00547bd0 (maptemplate.o) PID 5464
> gcc: no input files
> Got a SIGCHLD; 1 unreaped children.
> Reaping losing child 0x00547bd0 PID 5464
> make: *** [maptemplate.o] Error 1
> Removing child 0x00547bd0 PID 5464 from chain.
I would check your ./configure again. Specifically, in the gcc compile
step, there should be something between the last "-I" and
"maptemplate.c". As it is, gcc is thinking that maptemplate.c is to be
included, when it's really what should be compiled.
I ran into this when I tried --with-proj without specifying a directory
after. You'd think the configure script would've noticed, but it
didn't. So I would check ./configure --help to see which of those flags
requires a path, and then try setting them.
--Colin McGuigan
