Compilation Error on 64 bit Fedora Core 3
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Tue Jan 18 09:41:10 PST 2005
After running configure, open your Makefile and and look for the line that
contains GEOS_INC. You'll probably find it's lacking the path to your GEOS
include files. Add -I/usr/include (or whatever the path to your GEOS
headers).
It seems MapServer's configure script doesn't get the include path from
geos-config properly. An alternative is to not include the --with-geos
parameter. I don't think MapServer uses GEOS natively at the moment anyway.
Good luck!
-Perry N.
On Tuesday 18 January 2005 08:58 am, Colin McGuigan wrote:
> Tony Baylis wrote:
> > We are trying to upgrade our Mapserver app from 3.6.6 to the latest
> on a new
> > 64 bit machine using Fedora Core 3.
> > After trying to install from .src.rpm and encountering issues related to
> > 64bit, I have started again using .tar.gz files for all packages except
> > those that can be installed or updated using yum, ie devel packages etc.
> > The following ./configure command was used and succeeded:
> > ./configure --with-jpeg --with-php=/usr/include/php/main
> > --with-php-regex-dir=/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex
> > --with-gdal --with-png --with-wmsclient --with-libwww --without-tiff
> > --with-geos --with-postgis --with-freetype --enable-force-freetype1
> > --enable-runpath
> > BUT compilation (make -d) fails giving the following final output:
> > Finished prerequisites of target file `maptemplate.o'.
> > Must remake target `maptemplate.o'.
> > gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL
> > -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> > -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_GEOS
> > -DUSE_ICONV -DUSE_PHP_REGEX
> > -I/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex/.. -DUSE_POSTGIS
> > -I/usr/include -I/usr/local/include -I/usr/include -I
> > maptemplate.c -o maptemplate.o
> > Putting child 0x00547bd0 (maptemplate.o) PID 5464 on the chain.
> > Live child 0x00547bd0 (maptemplate.o) PID 5464
> > gcc: no input files
> > Got a SIGCHLD; 1 unreaped children.
> > Reaping losing child 0x00547bd0 PID 5464
> > make: *** [maptemplate.o] Error 1
> > Removing child 0x00547bd0 PID 5464 from chain.
> I would check your ./configure again. Specifically, in the gcc compile
> step, there should be something between the last "-I" and
> "maptemplate.c". As it is, gcc is thinking that maptemplate.c is to be
> included, when it's really what should be compiled.
> I ran into this when I tried --with-proj without specifying a directory
> after. You'd think the configure script would've noticed, but it
> didn't. So I would check ./configure --help to see which of those flags
> requires a path, and then try setting them.
> --Colin McGuigan
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
More information about the MapServer-users
