Compilation Error on 64 bit Fedora Core 3
Tony Baylis
tonyb at BUNDABERG.QLD.GOV.AU
Tue Jan 18 17:49:05 EST 2005
Thanks to all who replied...
I also assumed the problem related to a missing path before maptemplate.c.
All the options mentioned have been tried, including removing --with-geos,
adding -m32 to the gcc line in the Makefile to get it compiled as 32bit but
to no avail as yet.
I shall keep trying...I too have learnt(?) more about compilers and Makefiles
than I thought I needed to know over the last week...
Tony
On Wednesday 19 January 2005 03:41, Pericles S. Nacionales wrote:
> After running configure, open your Makefile and and look for the line that
> contains GEOS_INC. You'll probably find it's lacking the path to your GEOS
> include files. Add -I/usr/include (or whatever the path to your GEOS
> headers).
> It seems MapServer's configure script doesn't get the include path from
> geos-config properly. An alternative is to not include the --with-geos
> parameter. I don't think MapServer uses GEOS natively at the moment
> anyway.
> Good luck!
> -Perry N.
> On Tuesday 18 January 2005 08:58 am, Colin McGuigan wrote:
> > Tony Baylis wrote:
> > > We are trying to upgrade our Mapserver app from 3.6.6 to the latest
> > on a new
> > > 64 bit machine using Fedora Core 3.
> > > After trying to install from .src.rpm and encountering issues related
> > > to 64bit, I have started again using .tar.gz files for all packages
> > > except those that can be installed or updated using yum, ie devel
> > > packages etc.
> > > The following ./configure command was used and succeeded:
> > > ./configure --with-jpeg --with-php=/usr/include/php/main
> > > --with-php-regex-dir=/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex
> > > --with-gdal --with-png --with-wmsclient --with-libwww --without-tiff
> > > --with-geos --with-postgis --with-freetype --enable-force-freetype1
> > > --enable-runpath
> > > BUT compilation (make -d) fails giving the following final output:
> > > Finished prerequisites of target file `maptemplate.o'.
> > > Must remake target `maptemplate.o'.
> > > gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT
> > > -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> > > -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
> > > -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -DUSE_PHP_REGEX
> > > -I/usr/src/redhat/BUILD/php-4.3.10/build-cgi/regex/.. -DUSE_POSTGIS
> > > -I/usr/include -I/usr/local/include -I/usr/include -I
> > > maptemplate.c -o maptemplate.o
> > > Putting child 0x00547bd0 (maptemplate.o) PID 5464 on the chain.
> > > Live child 0x00547bd0 (maptemplate.o) PID 5464
> > > gcc: no input files
> > > Got a SIGCHLD; 1 unreaped children.
> > > Reaping losing child 0x00547bd0 PID 5464
> > > make: *** [maptemplate.o] Error 1
> > > Removing child 0x00547bd0 PID 5464 from chain.
> > I would check your ./configure again. Specifically, in the gcc compile
> > step, there should be something between the last "-I" and
> > "maptemplate.c". As it is, gcc is thinking that maptemplate.c is to be
> > included, when it's really what should be compiled.
> > I ran into this when I tried --with-proj without specifying a directory
> > after. You'd think the configure script would've noticed, but it
> > didn't. So I would check ./configure --help to see which of those flags
> > requires a path, and then try setting them.
> > --Colin McGuigan
> Dept. of Ecology, Evolution, and Behavior
> University of Minnesota
> work: 612 624 6713
> e-mail: nacional at cbs.umn.edu
Anthony Baylis
GIS Officer
Bundaberg City Council
ph 07 4153 9926
fax 07 4153 9238
e tonyb at bundaberg.qld.gov.au
web www.bundaberg.qld.gov.au
