looking for tile index example for tif's using Mapserver 4.02
Brent Fraser
bfraser at GEOANALYTIC.COM
Tue Jan 18 10:10:05 EST 2005
John,
The HowTo you refer to pretty much covers how to set up the tile index:
1. Organize your raster files into directories by coordinate system.
2. Create a tile index shapefile by running gdalindex
3. Create a layer entry in your Mapserver mapfile referencing the tile index shapefile
As for the viewer portion (HTML, Java, etc) of the MapServer system, there is nothing special about the tile index layer. It can be turned on and off just like your current raster layer.
I'm not sure if the "PROCESSING" directive works with a tile index layer; I've never tried it.
Brent Fraser
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, January 17, 2005 4:44 PM
Subject: [UMN_MAPSERVER-USERS] looking for tile index example for tif's using Mapserver 4.02
Hi
We need an example of how to set up a basic mapserver viewer that will display images using the tile index mentioned on page 3 of howto for RASTERS.
I have been successful creating a basic application which shows one "test" image as in my map file below... please fine at the start of the layers it is called 'Ptest":
Thank you for any help
John
# Start of map file
NAME Pville
STATUS ON
SIZE 600 600
EXTENT 401500 5461000 410000 5466600
UNITS METERS
FONTSET "C:\Inetpub\wwwroot\Parksville\fonts\fonts.list"
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER Pville_header.html
TEMPLATE Pville.html
FOOTER Pville_footer.html
MINSCALE 1000
#MAXSCALE 155000
MAXSCALE 40000
IMAGEPATH "set in Pville_init.html"
IMAGEURL "set in Pville_init.html"
METADATA
WMS_TITLE "UMN MapServer Parksville BC"
WMS_ABSTRACT "This is the UMN MapServer application for the City of Parksville located on Vancouver Island."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/Parksville/Pville_init.html"
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 12 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 0 0 0
UNITS METERS
INTERVALS 1
TRANSPARENT FALSE
STATUS EMBED
POSITION LR
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Rem March9,04
# Start of layer definitions
LAYER
NAME Ptest
TYPE RASTER
STATUS OFF
DATA test01NAD83.tif
PROCESSING "BANDS=1,2,3"
OFFSITE 71 74 65
END #LAYER
LAYER
NAME Pparks
TYPE POLYGON
STATUS OFF
DATA P83parks
LABELITEM "NAME"
LABELMAXSCALE 5000
CLASS
NAME Parks
COLOR 40 195 48
TEMPLATE "Parks.html"
LABEL
MINFEATURESIZE 40
MINDISTANCE 100
BUFFER 10
ANGLE AUTO
POSITION AUTO
SIZE MEDIUM
COLOR 0 0 0
END #LABEL
END #CLASS
HEADER "Parks_header.html"
FOOTER "Parks_footer.html"
END #LAYER
LAYER
NAME Pwatercourse
TYPE LINE
STATUS OFF
DATA P83watercourse
CLASS
NAME Watercourse
COLOR 49 117 185
END #CLASS
END #LAYER
LAYER
NAME Pwatflow
TYPE POLYGON
STATUS DEFAULT
DATA P83watflow
CLASS
NAME Pwatflow
COLOR 49 37 185
END #CLASS
END #LAYER
LAYER
NAME Ppoints
TYPE POINT
DATA P83points
STATUS DEFAULT
LABELITEM "NAME"
LABELMAXSCALE 2000
TOLERANCE 10
TOLERANCEUNITS PIXELS
CLASS
NAME 'Places'
TEMPLATE "Points.html"
STYLE
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
END #STYLE
LABEL
MINFEATURESIZE 10
MINDISTANCE 20
BUFFER 5
ANGLE AUTO
POSITION AUTO
SIZE SMALL
COLOR 128 255 164
END #LABEL
END #CLASS
HEADER "Points_header.html"
FOOTER "Points_footer.html"
END #LAYER
LAYER
NAME Proads
TYPE LINE
DATA P83roads
STATUS DEFAULT
MINSCALE 15000
LABELITEM "ROADNAME"
LABELMAXSCALE 80000
CLASS
NAME Roads
COLOR 0 0 0
SIZE 20
LABEL
TYPE TRUETYPE
FONT arial
MINFEATURESIZE 20
MINDISTANCE 100
BUFFER 10
ANGLE AUTO
POSITION AUTO
SIZE 6
COLOR 0 0 0
ANTIALIAS TRUE
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME Proadshide
TYPE LINE
DATA P83roads
STATUS DEFAULT
MAXSCALE 15000
CLASS
NAME Roads
#COLOR 255 255 255
SIZE 20
LABEL
TYPE TRUETYPE
FONT arial
MINFEATURESIZE 20
MINDISTANCE 150
BUFFER 10
ANGLE AUTO
POSITION AUTO
SIZE 6
COLOR 0 0 0
ANTIALIAS TRUE
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME Pcad
TYPE POLYGON
STATUS DEFAULT
MAXSCALE 20000
DATA P83cad_Intersect
LABELITEM "CHOUSE"
LABELMAXSCALE 2000
CLASS
NAME Lots
TEMPLATE "Cad.html"
OUTLINECOLOR 200 200 200
LABEL
MINFEATURESIZE 10
MINDISTANCE 10
BUFFER 5
ANGLE AUTO
POSITION AUTO
SIZE MEDIUM
COLOR 0 0 0
END #LABEL
END #CLASS
HEADER "Cad_header.html"
FOOTER "Cad_footer.html"
END #LAYER
LAYER
NAME Pzoning
TYPE POLYGON
STATUS OFF
MAXSCALE 30000
DATA P83zoning
LABELITEM "Z"
LABELMAXSCALE 20000
CLASS
NAME Zoning
LABEL
MINFEATURESIZE 10
MINDISTANCE 10
BUFFER 5
ANGLE AUTO
POSITION AUTO
SIZE LARGE
COLOR 255 0 0
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME Pwater
TYPE LINE
STATUS OFF
MAXSCALE 15000
TOLERANCE 10
DATA P83water
CLASS
NAME Waterworks
TEMPLATE "Waterworks.html"
COLOR 0 0 255
END #CLASS
HEADER "Waterworks_header.html"
FOOTER "Waterworks_footer.html"
END #LAYER
LAYER
NAME Psanitary
TYPE LINE
STATUS OFF
MAXSCALE 15000
TOLERANCE 10
DATA P83sanitary
CLASS
NAME Sanitary
TEMPLATE 'Sanitary.html'
COLOR 204 102 0
END #CLASS
HEADER 'Sanitary_header.html'
FOOTER 'Sanitary_footer.html'
END #LAYER
LAYER
NAME Pstorm
TYPE LINE
STATUS OFF
MAXSCALE 15000
TOLERANCE 10
DATA P83storm
CLASS
NAME Storm
TEMPLATE "Storm.html"
COLOR 0 255 0
END #CLASS
HEADER "Storm_header.html"
FOOTER "Storm_footer.html"
END #LAYER
LAYER
NAME Ptrails
TYPE LINE
STATUS OFF
MAXSCALE 20000
DATA P83trails
CLASS
NAME Trails
COLOR 180 100 40
END #CLASS
END #LAYER
LAYER
NAME Pbuildings
TYPE LINE
STATUS OFF
MAXSCALE 20000
DATA P83buildings
CLASS
NAME Buildings
COLOR 255 175 175
END #CLASS
END #LAYER
LAYER
NAME Pboundary
TYPE LINE
STATUS DEFAULT
DATA P83boundary
CLASS
NAME Boundary
COLOR 255 0 255
END #CLASS
END #LAYER
END # Map File
John Wiley, C.Tech.
GIS Technologist
City of Parksville, BC
Direct 250 954 4696
Fax 250 248 6140
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050118/9cd21d10/attachment.html
