looking for tile index example for tif's using Mapserver 4.02
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Tue Jan 18 10:36:32 EST 2005
I can send you a tileindex shape file and map file example if you want it?
But you need to create your own tileindex for your own raster files
using some software ie.
gdaltindex.
Kristjan
> ----- Original Message -----
> *From:* John Wiley <mailto:JWiley at CITY.PARKSVILLE.BC.CA>
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> *Sent:* Monday, January 17, 2005 4:44 PM
> *Subject:* [UMN_MAPSERVER-USERS] looking for tile index example
> Hi
> We need an example of how to set up a basic mapserver viewer that
> will display images using the tile index mentioned on page 3 of
> howto for RASTERS.
> I have been successful creating a basic application which shows
> one "test" image as in my map file below... please fine at the
> start of the layers it is called 'Ptest":
> Thank you for any help
> John
> # Start of map file
> NAME Pville
> STATUS ON
> SIZE 600 600
> EXTENT 401500 5461000 410000 5466600
> UNITS METERS
> FONTSET "C:\Inetpub\wwwroot\Parksville\fonts\fonts.list"
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> # you may need to change this to match your MapServer build
> #IMAGETYPE PNG
> # Projection definition, consult the PROJ.4 documentation for
> parameter discussion
> #PROJECTION
> # "proj=utm"
> # "ellps=GRS80"
> # "zone=15"
> # "north"
> # "no_defs"
> # OR:
> # "init=epsg:26915"
> #END
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> HEADER Pville_header.html
> TEMPLATE Pville.html
> FOOTER Pville_footer.html
> MINSCALE 1000
> #MAXSCALE 155000
> MAXSCALE 40000
> IMAGEPATH "set in Pville_init.html"
> IMAGEURL "set in Pville_init.html"
> METADATA
> WMS_TITLE "UMN MapServer Parksville BC"
> WMS_ABSTRACT "This is the UMN MapServer application for the
> City of Parksville located on Vancouver Island."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://localhost/Parksville/Pville_init.html"
> WMS_SRS "EPSG:26915"
> END
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of reference map
> REFERENCE
> IMAGE graphics/reference.gif
> SIZE 120 120
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
> KEYSIZE 12 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE tiny
> END
> STYLE 1
> SIZE 80 2
> COLOR 0 0 0
> UNITS METERS
> INTERVALS 1
> TRANSPARENT FALSE
> STATUS EMBED
> POSITION LR
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> # Rem March9,04
> # Start of layer definitions
> LAYER
> NAME Ptest
> TYPE RASTER
> STATUS OFF
> DATA test01NAD83.tif
> PROCESSING "BANDS=1,2,3"
> OFFSITE 71 74 65
> END #LAYER
> LAYER
> NAME Pparks
> TYPE POLYGON
> STATUS OFF
> DATA P83parks
> LABELITEM "NAME"
> LABELMAXSCALE 5000
> CLASS
> NAME Parks
> COLOR 40 195 48
> TEMPLATE "Parks.html"
> LABEL
> MINFEATURESIZE 40
> MINDISTANCE 100
> BUFFER 10
> ANGLE AUTO
> POSITION AUTO
> SIZE MEDIUM
> COLOR 0 0 0
> END #LABEL
> END #CLASS
> HEADER "Parks_header.html"
> FOOTER "Parks_footer.html"
> END #LAYER
> LAYER
> NAME Pwatercourse
> TYPE LINE
> STATUS OFF
> DATA P83watercourse
> CLASS
> NAME Watercourse
> COLOR 49 117 185
> END #CLASS
> END #LAYER
> LAYER
> NAME Pwatflow
> TYPE POLYGON
> STATUS DEFAULT
> DATA P83watflow
> CLASS
> NAME Pwatflow
> COLOR 49 37 185
> END #CLASS
> END #LAYER
> LAYER
> NAME Ppoints
> TYPE POINT
> DATA P83points
> STATUS DEFAULT
> LABELITEM "NAME"
> LABELMAXSCALE 2000
> TOLERANCE 10
> TOLERANCEUNITS PIXELS
> CLASS
> NAME 'Places'
> TEMPLATE "Points.html"
> STYLE
> COLOR 128 255 164
> SYMBOL 'circle'
> SIZE 7
> END #STYLE
> LABEL
> MINFEATURESIZE 10
> MINDISTANCE 20
> BUFFER 5
> ANGLE AUTO
> POSITION AUTO
> SIZE SMALL
> COLOR 128 255 164
> END #LABEL
> END #CLASS
> HEADER "Points_header.html"
> FOOTER "Points_footer.html"
> END #LAYER
> LAYER
> NAME Proads
> TYPE LINE
> DATA P83roads
> STATUS DEFAULT
> MINSCALE 15000
> LABELITEM "ROADNAME"
> LABELMAXSCALE 80000
> CLASS
> NAME Roads
> COLOR 0 0 0
> SIZE 20
> LABEL
> TYPE TRUETYPE
> FONT arial
> MINFEATURESIZE 20
> MINDISTANCE 100
> BUFFER 10
> ANGLE AUTO
> POSITION AUTO
> SIZE 6
> COLOR 0 0 0
> ANTIALIAS TRUE
> END #LABEL
> END #CLASS
> END #LAYER
> LAYER
> NAME Proadshide
> TYPE LINE
> DATA P83roads
> STATUS DEFAULT
> MAXSCALE 15000
> CLASS
> NAME Roads
> #COLOR 255 255 255
> SIZE 20
> LABEL
> TYPE TRUETYPE
> FONT arial
> MINFEATURESIZE 20
> MINDISTANCE 150
> BUFFER 10
> ANGLE AUTO
> POSITION AUTO
> SIZE 6
> COLOR 0 0 0
> ANTIALIAS TRUE
> END #LABEL
> END #CLASS
> END #LAYER
> LAYER
> NAME Pcad
> TYPE POLYGON
> STATUS DEFAULT
> MAXSCALE 20000
> DATA P83cad_Intersect
> LABELITEM "CHOUSE"
> LABELMAXSCALE 2000
> CLASS
> NAME Lots
> TEMPLATE "Cad.html"
> OUTLINECOLOR 200 200 200
> LABEL
> MINFEATURESIZE 10
> MINDISTANCE 10
> BUFFER 5
> ANGLE AUTO
> POSITION AUTO
> SIZE MEDIUM
> COLOR 0 0 0
> END #LABEL
> END #CLASS
> HEADER "Cad_header.html"
> FOOTER "Cad_footer.html"
> END #LAYER
> LAYER
> NAME Pzoning
> TYPE POLYGON
> STATUS OFF
> MAXSCALE 30000
> DATA P83zoning
> LABELITEM "Z"
> LABELMAXSCALE 20000
> CLASS
> NAME Zoning
> LABEL
> MINFEATURESIZE 10
> MINDISTANCE 10
> BUFFER 5
> ANGLE AUTO
> POSITION AUTO
> SIZE LARGE
> COLOR 255 0 0
> END #LABEL
> END #CLASS
> END #LAYER
> LAYER
> NAME Pwater
> TYPE LINE
> STATUS OFF
> MAXSCALE 15000
> TOLERANCE 10
> DATA P83water
> CLASS
> NAME Waterworks
> TEMPLATE "Waterworks.html"
> COLOR 0 0 255
> END #CLASS
> HEADER "Waterworks_header.html"
> FOOTER "Waterworks_footer.html"
> END #LAYER
> LAYER
> NAME Psanitary
> TYPE LINE
> STATUS OFF
> MAXSCALE 15000
> TOLERANCE 10
> DATA P83sanitary
> CLASS
> NAME Sanitary
> TEMPLATE 'Sanitary.html'
> COLOR 204 102 0
> END #CLASS
> HEADER 'Sanitary_header.html'
> FOOTER 'Sanitary_footer.html'
> END #LAYER
> LAYER
> NAME Pstorm
> TYPE LINE
> STATUS OFF
> MAXSCALE 15000
> TOLERANCE 10
> DATA P83storm
> CLASS
> NAME Storm
> TEMPLATE "Storm.html"
> COLOR 0 255 0
> END #CLASS
> HEADER "Storm_header.html"
> FOOTER "Storm_footer.html"
> END #LAYER
> LAYER
> NAME Ptrails
> TYPE LINE
> STATUS OFF
> MAXSCALE 20000
> DATA P83trails
> CLASS
> NAME Trails
> COLOR 180 100 40
> END #CLASS
> END #LAYER
> LAYER
> NAME Pbuildings
> TYPE LINE
> STATUS OFF
> MAXSCALE 20000
> DATA P83buildings
> CLASS
> NAME Buildings
> COLOR 255 175 175
> END #CLASS
> END #LAYER
> LAYER
> NAME Pboundary
> TYPE LINE
> STATUS DEFAULT
> DATA P83boundary
> CLASS
> NAME Boundary
> COLOR 255 0 255
> END #CLASS
> END #LAYER
> END # Map File
> John Wiley, C.Tech.
> GIS Technologist
> City of Parksville, BC
> Direct 250 954 4696
> Fax 250 248 6140
