label angle AUTO - M.S. 4.4.
Rob P.
rob at DATAFLOWDESIGN.COM
Tue Jan 18 13:47:23 EST 2005
>>>>> "Piero" == Piero Cavalieri <piero.cavalieri at HEIDI.IT> writes:
Piero> I'm trying to use the AUTO orientation of label in this
Piero> .map file fragment: LAYER NAME fiumi DEBUG on METADATA
Piero> "DESCRIPTION" "Fiumi" END TYPE line STATUS ON DATA idrfiu
Piero> LABELITEM "des" LABELMAXSCALE 100000 CLASSITEM "asta" CLASS
Piero> EXPRESSION "0000" NAME "Fiumi/Aste Principali" COLOR 0 0
Piero> 250 TEMPLATE "ttt_query.html" LABEL MINFEATURESIZE 30
Piero> MINDISTANCE 150 POSITION CC SIZE MEDIUM ANGLE AUTO COLOR 0
Piero> 0 100 OUTLINECOLOR 220 220 220 END END CLASS EXPRESSION
Piero> /F|C|./ NAME "Fiumi/Fosse o Canali" MAXSCALE 40000 COLOR 0
Piero> 0 250 TEMPLATE "ttt_query.html" LABEL MINFEATURESIZE 30
Piero> MINDISTANCE 150 POSITION CC ANGLE AUTO SIZE SMALL COLOR 0 0
Piero> 100 OUTLINECOLOR 220 220 220 END END TOLERANCE 5 END
Piero> but it has no effect. My labels are still orrizontal. If I
Piero> use a background color for labels, then only the background
Piero> is rotated. What's wrong in my .map ?
I think you need to add:
TYPE truetype
in the label block. Also, you need to specify FONTSET in the MAP
block.
Rob
