label angle AUTO - M.S. 4.4.
Gregory S. Williamson
gsw at GLOBEXPLORER.COM
Tue Jan 18 15:45:59 EST 2005
I think the AUTO angle feature only works with true type fonts; you seem to be using bitmap fonts (SIZE MEDIUM) ... try setting up this layer to use truetype and I bet the autoangle feature will work as advertised.
In the map definition something like this (from a windoze box)
FONTSET "C:\ms4w\Apache\htdocs\ssf\fonts\fonts.list"
TEXT ([FENAME] [FETYPE] #[FRADDL]-#[TOADDR])
LABEL
ANGLE auto
ANTIALIAS true
MINFEATURESIZE 20
MINDISTANCE 60
TYPE TRUETYPE
FONT arial-bold
SIZE 9
POSITION CC
BUFFER 5
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: Piero Cavalieri [mailto:piero.cavalieri at HEIDI.IT]
Sent: Tue 1/18/2005 9:18 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Cc:
Subject: [UMN_MAPSERVER-USERS] label angle AUTO - M.S. 4.4.
I'm trying to use the AUTO orientation of label in this .map file fragment:
LAYER
NAME fiumi
DEBUG on
METADATA
"DESCRIPTION" "Fiumi"
END
TYPE line
STATUS ON
DATA idrfiu
LABELITEM "des"
LABELMAXSCALE 100000
CLASSITEM "asta"
CLASS
EXPRESSION "0000"
NAME "Fiumi/Aste Principali"
COLOR 0 0 250
TEMPLATE "ttt_query.html"
LABEL
MINFEATURESIZE 30
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
ANGLE AUTO
COLOR 0 0 100
OUTLINECOLOR 220 220 220
END
END
CLASS
EXPRESSION /F|C|./
NAME "Fiumi/Fosse o Canali"
MAXSCALE 40000
COLOR 0 0 250
LABEL
MINFEATURESIZE 30
MINDISTANCE 150
POSITION CC
ANGLE AUTO
SIZE SMALL
COLOR 0 0 100
END
END
TOLERANCE 5
END
but it has no effect. My labels are still orrizontal.
If I use a background color for labels, then only the background is rotated.
What's wrong in my .map ?
Thanks in advance
Piero
