WMS error after upgrade to 4.4
Tracy Howlett
Tracy at CHIRPWHISTLER.INFO
Wed Jan 19 20:28:54 EST 2005
Here is my getmap request:
http://www.chirpwhistler.info/scripts/mapserv.exe?map=chirp_wms.map&VERSION=
1.1.1&SERVICE=wms&REQUEST=GetMap
And here is the sample of my cascading mapfile and the base mapfile
I really appreciate your help!
Cascade (c:\inetpub\scripts\chirp_wms.map):
# Start of map file
# Sample map file for a chameleon app.
NAME CHIRP_WMS
STATUS ON
SIZE 570 360
SYMBOLSET "c:\chameleon-2.0\CHiRP\etc\symbols.sym"
EXTENT 486515 5541282 512169 5559285
UNITS METERS
SHAPEPATH "c:\chameleon-2.0\CHiRP\data\"
IMAGECOLOR 255 255 255
FONTSET "c:\chameleon-2.0\CHiRP\etc\fonts.txt"
# Start of web interface definition
WEB
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "CHIRP_WMS"
"wms_onlineresource"
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
P\map\chirp.map&"
END
END
PROJECTION
"init=epsg:26910"
END
# Start of layer definitions
LAYER
NAME "RMOW Boundary"
TYPE RASTER
STATUS ON
CONNECTION
"http://localhost/scripts/mapserv.exe?map=c:\c:\chameleon-2.0\chirp\map\chir
p.map&"
CONNECTIONTYPE WMS
METADATA
"wms_title" "RMOW"
"wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326
EPSG:42304 EPSG:26910"
"wms_name" "RMOW "
"wms_server_version" "1.11"
"wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
"wms_format" "image/gif"
END
END
LAYER
NAME "Municipal Park"
TYPE RASTER
STATUS ON
CONNECTION
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\chir
p\map\chirp.map&"
CONNECTIONTYPE WMS
METADATA
"wms_title" "Park"
"wms_name" "Park"
"wms_server_version" "1.1.1"
END
LAYER
NAME "Buildings"
TYPE RASTER
STATUS ON
CONNECTION
P\map\chirp.map&"
CONNECTIONTYPE WMS
METADATA
"wms_title" "Buildings"
"wms_srs" "EPSG:26910"
"wms_name" "Buildings"
END
END
Base MapFile (c:\chameleon-2.0\chirp\map\chirp.map):
# Start of map file
NAME CHiRP
STATUS ON
SIZE 570 360
SYMBOLSET "../etc/symbols.sym"
UNITS METERS
SHAPEPATH "../data/"
FONTSET "../etc/fonts.txt"
WEB
MINSCALE 1300
MAXSCALE 13000000000
IMAGEURL "/tmp/"
# LOG "/tmp/gmap.log"
METADATA
"wms_title" "CHiRP"
"http://www.CHiRPwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
P\map\chirp.map&"
END
END
# Start of reference map
REFERENCE
IMAGE images/whistler_sm.png
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 75 50
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
# LABEL object
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
TEMPLATE "legend3.html"
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 150 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS Kilometers
INTERVALS 5
STATUS ON
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
PROJECTION
"init=epsg:26910"
END
# MUNICIPAL PARK
LAYER
GROUP "Recreation"
TYPE POLYGON
DUMP TRUE
TEMPLATE "blank.html"
TOLERANCE 10
TOLERANCEUNITS PIXELS
STATUS ON
DATA "Park"
PROJECTION
"init=epsg:26910"
END
CLASS
COLOR 150 231 138
END
METADATA
WMS_GROUP_TITLE "Recreation"
WMS_TITLE "Park"
WMS_ABSTRACT "Park"
WMS_SRS "EPSG:26910"
END
END
# RMOW BOUNDARY
LAYER
NAME "Resort Municipality of Whistler"
TYPE LINE
STATUS ON
GROUP "Boundaries"
DATA "RMOW"
PROJECTION
"init=epsg:26910"
END
CLASS
COLOR 168 0 0
SYMBOL "Line"
SIZE 2
END
METADATA
WMS_GROUP_TITLE "Boundaries"
WMS_TITLE "RMOW"
WMS_ABSTRACT "Resort Municipality of Whistler Boundary"
END
END
# BUILDINGS
LAYER
NAME "Buildings"
GROUP "Civic Information"
TYPE POLYGON
DATA "Building"
MAXSCALE 15000
STATUS ON
TOLERANCE 10
CLASSITEM "Class"
PROJECTION
"init=epsg:26910"
END
CLASS
NAME "Accomodation"
EXPRESSION "Accomodation"
OUTLINECOLOR 0 0 0
COLOR 230 0 0
END
CLASS
NAME "Commercial"
EXPRESSION "Commercial"
OUTLINECOLOR 0 0 0
COLOR 0 77 168
END
CLASS
NAME "Residential"
EXPRESSION "Residential"
OUTLINECOLOR 0 0 0
COLOR 200 133 68
END
CLASS
NAME "Lift Base"
EXPRESSION "Lift Base"
OUTLINECOLOR 0 0 0
COLOR 0 0 0
END
CLASS
NAME "Municipal"
EXPRESSION "Municipal"
OUTLINECOLOR 0 0 0
COLOR 130 155 90
END
CLASS
NAME "Other"
OUTLINECOLOR 0 0 0
EXPRESSION ""
COLOR 130 130 130
END
CLASS
NAME "Commercial"
COLOR 0 77 168
END
METADATA
WMS_GROUP_TITLE "CivicInformation"
WMS_TITLE "Buildings"
WMS_ABSTRACT "Buildings"
END
END
Tracy Howlett
Community Habitat Resources Project
GIS Web Development Coordinator
PO Box 1122, Whistler, BC, V0N 1B8
Phone: 604 932 2019
Fax: 604 932 2077
Web: www.CHiRPwhistler.info
Forum: www.CHiRPwhistler.info/forums/index.php
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Wednesday, January 19, 2005 5:18 PM
To: Tracy Howlett
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS error after upgrade to 4.4
Do you have an example of a getmap URL returing the exception and maybe
your map definition ?
There has been some work done in the wms code before the 4.4 release so
that mapserver would be OGC compliant (so more parameter tesing and
exception generating has been added) and this may explain the problems
your are having.
Later,
Tracy Howlett wrote:
> Hello,
> I've recently upgraded to MapServer 4.4 after running 4.0.1 successfully
> for over a year. I have been using a Cascading WMS service to share
> some of my layers out to another MapServer user who has been accessing
> my data without problem.
> For some reason, now that MapServer 4.4 is running, the WMS layers are
> no longer being shared. We have run the getCapabilities for both my
> base mapfile and my cascaded map file service and they both come back
> error free but when we run a getMap we receive the following error:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
> ServiceExceptionReport SYSTEM
> "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1"> <ServiceException
> code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
> LAYERS parameter.
> </ServiceException>
> </ServiceExceptionReport>
> I've read about this error in the archives but cannot find a solution
> for my particular file. When my colleague calls the mapfile only one of
> the 10 layers listed is returned.
> The data has not changed since I upgraded and it is all in the same
> projection (UTM Zone 10). Are there some naming conventions or WMS
> requirements that are new in 4.4 that I have not found in the
documentation?
> Any help would be greatly appreciated as we are trying to get this thing
> up and running again for a presentation on Saturday.
> Thanks,
> **Tracy Howlett**
> Phone: 604 932 2019
> Fax: 604 932 2077
> Web: www.CHiRPwhistler.info <http://www.CHiRPwhistler.info>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
