First-time user needs help with mapfile
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Wed Jan 19 22:24:37 EST 2005
Keerati,
A few things I spotted (which may not necessarily be all problems) :
- Your mapfile should have an output format:
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
If you don't have it, it may still work, but it will use the default format.
- Your layer must have a class. This defines what it looks like. Without it, it will definitely not show anything:
CLASS
NAME "countries" # this must be there to show it in the legend
COLOR 255 255 180 # the fill colour
OUTLINECOLOR 0 0 0 # the boundary colour
END
- last thing: better not put spaces in your filenames. It may work, but I could well imagine if it didn't.
Try these and see what happens.
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Keerati Inochanon
Sent: 20 January 2005 11:06
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] First-time user needs help with mapfile
I'm new at GIS and mapserver, and just decided to try it out. I was
wondering if someone could guide me into the right direction. I
downloaded world base map shapefiles from esri website. I wrote a
mapfile for it, and tried to have mapscript render it, but it does not
work (image produced, but only background). Here is what my map file
looks like:
MAP
NAME ASIA
STATUS ON
SIZE 800 500
IMAGETYPE PNG
IMAGECOLOR 240 240 240
SHAPEPATH "C:\\Program Files\\Apache
Group\\Apache2\\htdocs\\mapserver\\testshp"
EXTENT 90.0168 0.6079 113.5783 24.1694
UNITS DD
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
LAYER
NAME "boundaries"
TYPE POLYGON
STATUS ON
DATA "Country Boundaries 3"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
END
END
I got the extent info from the download page of the dataset
These are the files in the testshp directory:
B_Major Cities 1.dbf
B_Major Cities 1.prj
B_Major Cities 1.shp
B_Major Cities 1.shx
Country Boundaries 3.dbf
Country Boundaries 3.prj
Country Boundaries 3.shp
Country Boundaries 3.shx
Rivers 2.dbf
Rivers 2.prj
Rivers 2.shp
Rivers 2.shx
Streets and Railroads 1.dbf
Streets and Railroads 1.prj
Streets and Railroads 1.shp
Streets and Railroads 1.shx
Water Bodies 2.dbf
Water Bodies 2.prj
Water Bodies 2.shp
Water Bodies 2.shx
Any help or suggestions will be much appreciated. Thank you very much!
Keerati
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050120/b52e5f86/attachment.html
