.tab and .map
Jose Luis Gonzalez
joseluismapserver at YAHOO.ES
Thu Jan 20 12:02:42 EST 2005
So the only thing that you done is to add the
projection definition below in the .map file, and
thanks to that you can view the tiff file? Is that
correct?
By the way, what is tmerc mean?
All I want to do is to view the tiff file in a web
page and then situate some points in it (UTM
coordinates).
If you can guide me more in the way of doing it I will
be very greatfull.
I use Mapserver 4.4.0 and java (servlets)
Thank you
Jose Luis
--- Trent Burton <tburton at holonics.ca> escribió:
> Yes, I resolved the issue.
> There was no EPSG code available for my dataset so I
> ended up having to create the projection 'manually'.
> I ended up having to go back to the person who gave
> me the data to get all the specific projection
> information. You can see what I ended up as the
> projection for this layer in the projection
> definition below:
> PROJECTION
> "+proj=tmerc +lat_0=0 +lon_0=-76.5 +k=0.9999
> +x_0=304800 +y_0=0"
> END
> Trent
> -----Original Message-----
> From: Jose Luis Gonzalez
> [mailto:joseluismapserver at yahoo.es]
> Sent: Thursday, January 20, 2005 10:41 AM
> To: Trent Burton
> Subject: .tab and .map
> Hi Trent
> I have read that you had a similar problem than me
> and
> I would like to know if you managed to resolve your
> doubt. If so please tell me the answer.
> Thank you
> You wrote:
> Can someone tell me the projection entry into a map
> file for the
> following Mapinfo tif .tab entry, or better yet,
> explain to me how this
> works?
> !table
> !version 300
> !charset WindowsLatin1
> Definition table
> File "35j04_1614.tif"
> Type "RASTER"
> (347739.77,6898820.51) (0,0) Label "Pt 1",
> (349059.02,6898820.51) (5277,0) Label "Pt 2",
> (349059.02,6897411.01) (5277,5638) Label "Pt 3",
> (347739.77,6897411.01) (0,5638) Label "Pt 4"
> CoordSys Earth Projection 8, 33, "m", -76.5, 0,
> 0.9999, 304800, 0
> BOUNDS (-7943519.03923, -10000965.5329)
> (8553119.03923, 10000965.5329)
> Units "m"
> =20
> =20
> =20
> I assume that SUPPORTS=3DPROJ means that my
> mapserver
> was compiled with
> PROJ.4?
> Thanks,
> Trent
> ______________________________________________
> Renovamos el Correo Yahoo!: ¡250 MB GRATIS!
> Nuevos servicios, más seguridad
> http://correo.yahoo.es
