WMS error after upgrade to 4.4
Tracy Howlett
Tracy at CHIRPWHISTLER.INFO
Thu Jan 20 09:30:30 PST 2005
Hmmm - thanks a lot for your help but I'm still getting the layer error.
Can you tell me what I need to do to make my layers OGC compliant?
Tracy Howlett
Community Habitat Resources Project
GIS Web Development Coordinator
PO Box 1122, Whistler, BC, V0N 1B8
Phone: 604 932 2019
Fax: 604 932 2077
Web: www.CHiRPwhistler.info
Forum: www.CHiRPwhistler.info/forums/index.php
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Thursday, January 20, 2005 7:27 AM
To: Tracy at CHiRPwhistler.info
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS error after upgrade to 4.4
Not sure what might be the problem, but I have tested your wms client
map file and spotted a couple of issues in the first layer (RMOW
bounadary) :
- "wms_name" "RMOW " : from your server file definition,
this should be "RMOW" with no white space. Maybe mapserver should
automatically strip white spaces but in any case you should chnage it.
"wms_server_version" "1.11" : should be 1.1.1
After these 2 corrections, I was able to dsiplay the map.
Hope it helps.
Later,
Tracy Howlett wrote:
> Here is my getmap request:
http://www.chirpwhistler.info/scripts/mapserv.exe?map=chirp_wms.map&VERSION=
> 1.1.1&SERVICE=wms&REQUEST=GetMap
> And here is the sample of my cascading mapfile and the base mapfile
> I really appreciate your help!
> Cascade (c:\inetpub\scripts\chirp_wms.map):
> # Start of map file
> # Sample map file for a chameleon app.
> NAME CHIRP_WMS
> STATUS ON
> SIZE 570 360
> SYMBOLSET "c:\chameleon-2.0\CHiRP\etc\symbols.sym"
> EXTENT 486515 5541282 512169 5559285
> UNITS METERS
> SHAPEPATH "c:\chameleon-2.0\CHiRP\data\"
> IMAGECOLOR 255 255 255
> FONTSET "c:\chameleon-2.0\CHiRP\etc\fonts.txt"
> # Start of web interface definition
> WEB
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "/tmp/ms_tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "CHIRP_WMS"
> "wms_onlineresource"
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
> P\map\chirp.map&"
> END
> END
> PROJECTION
> "init=epsg:26910"
> END
> # Start of layer definitions
> LAYER
> NAME "RMOW Boundary"
> TYPE RASTER
> STATUS ON
> CONNECTION
"http://localhost/scripts/mapserv.exe?map=c:\c:\chameleon-2.0\chirp\map\chir
> p.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "RMOW"
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326
> EPSG:42304 EPSG:26910"
> "wms_name" "RMOW "
> "wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
> "wms_format" "image/gif"
> END
> END
> LAYER
> NAME "Municipal Park"
> TYPE RASTER
> STATUS ON
> CONNECTION
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\chir
> p\map\chirp.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Park"
> "wms_name" "Park"
> "wms_server_version" "1.1.1"
> END
> LAYER
> NAME "Buildings"
> TYPE RASTER
> STATUS ON
> CONNECTION
> P\map\chirp.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Buildings"
> "wms_srs" "EPSG:26910"
> "wms_name" "Buildings"
> END
> END
> Base MapFile (c:\chameleon-2.0\chirp\map\chirp.map):
> # Start of map file
> NAME CHiRP
> STATUS ON
> SIZE 570 360
> SYMBOLSET "../etc/symbols.sym"
> UNITS METERS
> SHAPEPATH "../data/"
> FONTSET "../etc/fonts.txt"
> WEB
> MINSCALE 1300
> MAXSCALE 13000000000
> IMAGEURL "/tmp/"
> # LOG "/tmp/gmap.log"
> METADATA
> "wms_title" "CHiRP"
"http://www.CHiRPwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
> P\map\chirp.map&"
> END
> END
> # Start of reference map
> REFERENCE
> IMAGE images/whistler_sm.png
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> SIZE 75 50
> END
> # Start of legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> # LABEL object
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> TEMPLATE "legend3.html"
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 150 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS Kilometers
> INTERVALS 5
> STATUS ON
> END
> QUERYMAP
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> PROJECTION
> "init=epsg:26910"
> END
> # MUNICIPAL PARK
> LAYER
> GROUP "Recreation"
> TYPE POLYGON
> DUMP TRUE
> TEMPLATE "blank.html"
> TOLERANCE 10
> TOLERANCEUNITS PIXELS
> STATUS ON
> DATA "Park"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> COLOR 150 231 138
> END
> METADATA
> WMS_GROUP_TITLE "Recreation"
> WMS_TITLE "Park"
> WMS_ABSTRACT "Park"
> WMS_SRS "EPSG:26910"
> END
> END
> # RMOW BOUNDARY
> LAYER
> NAME "Resort Municipality of Whistler"
> TYPE LINE
> STATUS ON
> GROUP "Boundaries"
> DATA "RMOW"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> COLOR 168 0 0
> SYMBOL "Line"
> SIZE 2
> END
> METADATA
> WMS_GROUP_TITLE "Boundaries"
> WMS_TITLE "RMOW"
> WMS_ABSTRACT "Resort Municipality of Whistler Boundary"
> END
> END
> # BUILDINGS
> LAYER
> NAME "Buildings"
> GROUP "Civic Information"
> TYPE POLYGON
> DATA "Building"
> MAXSCALE 15000
> STATUS ON
> TOLERANCE 10
> CLASSITEM "Class"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> NAME "Accomodation"
> EXPRESSION "Accomodation"
> OUTLINECOLOR 0 0 0
> COLOR 230 0 0
> END
> CLASS
> NAME "Commercial"
> EXPRESSION "Commercial"
> OUTLINECOLOR 0 0 0
> COLOR 0 77 168
> END
> CLASS
> NAME "Residential"
> EXPRESSION "Residential"
> OUTLINECOLOR 0 0 0
> COLOR 200 133 68
> END
> CLASS
> NAME "Lift Base"
> EXPRESSION "Lift Base"
> OUTLINECOLOR 0 0 0
> COLOR 0 0 0
> END
> CLASS
> NAME "Municipal"
> EXPRESSION "Municipal"
> OUTLINECOLOR 0 0 0
> COLOR 130 155 90
> END
> CLASS
> NAME "Other"
> OUTLINECOLOR 0 0 0
> EXPRESSION ""
> COLOR 130 130 130
> END
> CLASS
> NAME "Commercial"
> COLOR 0 77 168
> END
> METADATA
> WMS_GROUP_TITLE "CivicInformation"
> WMS_TITLE "Buildings"
> WMS_ABSTRACT "Buildings"
> END
> END
> Tracy Howlett
> Phone: 604 932 2019
> Fax: 604 932 2077
> Sent: Wednesday, January 19, 2005 5:18 PM
> To: Tracy Howlett
> Do you have an example of a getmap URL returing the exception and maybe
> your map definition ?
> There has been some work done in the wms code before the 4.4 release so
> that mapserver would be OGC compliant (so more parameter tesing and
> exception generating has been added) and this may explain the problems
> your are having.
> Later,
>>Hello,
>>I've recently upgraded to MapServer 4.4 after running 4.0.1 successfully
>>for over a year. I have been using a Cascading WMS service to share
>>some of my layers out to another MapServer user who has been accessing
>>my data without problem.
>>For some reason, now that MapServer 4.4 is running, the WMS layers are
>>no longer being shared. We have run the getCapabilities for both my
>>base mapfile and my cascaded map file service and they both come back
>>error free but when we run a getMap we receive the following error:
>><?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
>>ServiceExceptionReport SYSTEM
>>"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
>><ServiceExceptionReport version="1.1.1"> <ServiceException
>>code="LayerNotDefined">
>>msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
>>LAYERS parameter.
>></ServiceException>
>></ServiceExceptionReport>
>>I've read about this error in the archives but cannot find a solution
>>for my particular file. When my colleague calls the mapfile only one of
>>the 10 layers listed is returned.
>>The data has not changed since I upgraded and it is all in the same
>>projection (UTM Zone 10). Are there some naming conventions or WMS
>>requirements that are new in 4.4 that I have not found in the
> documentation?
>>Any help would be greatly appreciated as we are trying to get this thing
>>up and running again for a presentation on Saturday.
>>Thanks,
>>**Tracy Howlett**
>>Phone: 604 932 2019
>>Fax: 604 932 2077
>>Web: www.CHiRPwhistler.info <http://www.CHiRPwhistler.info>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the MapServer-users
