Solved: [UMN_MAPSERVER-USERS] PostGIS Connection Trouble
Arnulf Christl (CCGIS) arnulf.christl at CCGIS.DE
Fri Jan 21 05:04:01 PST 2005
thanx a lot - the capitals were the problem. Stupid me, yet again! Maybe
somebody (Paul :-) will have pity on me and remedy this capital string
problem. Else you tell me why these work:
DATA "geom from (select geom as geom, fld2 as fld2 from tab)as foo using
unique oid SRID=12345"
DATA "geom from (SELECT geom AS geom, fld2 AS fld2 FROM tab)as foo using
and these wont:
DATA "geom from (select geom as geom, fld2 as fld2 from tab)AS foo using
While you are at it don't forget to bump up the PostGIS version from 0.9
to 1.0...
Best regards,
Arnulf
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=623
> Sean
> On Jan 20, 2005, at 10:38 AM, Steven Monai wrote:
>> Whoops, guess I should be a little more observant. You're using a
>> recent
>> version of MapServer. Is it possible that the PostGIS-keyword-case bug
>> is
>> still alive?
>> -Steve M.
>> On Wed, 19 Jan 2005 18:05:19 +0100, Arnulf Christl
>> <arnulf.christl at CCGIS.DE> wrote:
>>> Hi,
>>> I am at a loss, we use MapServer/PostGIS every day but this one wont
>>> work.
>>> PostgreSQL 7.4.2
>>> PostGIS 0.9.0
>>> SuSE Linux Enterprise Server 9
>>> <!-- MapServer version 4.4.1 OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP
>>> SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER
>>> SUPPORTS=3DWMS_CL=
>> IENT
>>> SUPPORTS=3DWFS_SERVER SUPPORTS=3DWFS_CLIENT SUPPORTS=3DWCS_SERVER
>>> INPUT=3DPOSTGIS INPUT=3DORACLESPATIAL INPUT=3DOGR INPUT=3DGDAL
>>> INPUT=3DSHAP=
>> EFILE -->
>>> The error message looks strange to me, never saw that one. Especially
>>> the part:
>>> "oid::text from WHERE &&"
>>> Anybody any idea? See the MAP-file DATA string at the bottom.
>>> <?xml version=3D'1.0' encoding=3D"ISO-8859-1" standalone=3D"no" ?>
>>> <!DOCTYPE ServiceExceptionReport SYSTEM
>>> "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
>>> <ServiceExceptionReport version=3D"1.1.1">
>>> <ServiceException>
>>> msDrawMap(): Image handling error. Failed to draw layer named
>>> 'poly'.
>>> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
>>> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
>>> asbinary(force_collection(force_2d()),'NDR'),oid::text from
>>> WHERE && setSRID('BOX3D(3275833.33333155
>>> 5400833.33332511,3524166.66666667 5649166.66666667)'::BOX3D,
>>> find_srid('','','') )'
>>> <br><br>
>>> Postgresql reports the error as 'FEHLER: Fehler =C2=BBsyntax
>>> error=C2=AB=
>>  bei
>>> =C2=BBWHERE=C2=AB at character 104
>>> '<br><br>
>>> More Help:<br><br>
>>> Error with POSTGIS data variable. You specified '&lt;check
>>> your
>>> .map file&gt;'.<br>
>>> Standard ways of specifiying are : <br>
>>> (1) 'geometry_column from geometry_table' <br>
>>> (2) 'geometry_column from (&lt;sub query&gt;) as foo using
>>> unique &lt;column name&gt; using
>>> SRID=3D&lt;srid#&gt;'
>>> <br><br>
>>> Make sure you put in the 'using unique &lt;column
>>> name&gt;' and 'using SRID=3D#' clauses in.
>>> <br><br>For more help, please see
>>> http://postgis.refractions.net/documentation.php
>>> <br><br>Mappostgis.c - version of Jan 23/2004.
>>> msPOSTGISLayerParseData(): Query error. Error parsing POSTGIS data
>>> variable. Must contain 'geometry_column from table_name' or
>>> 'geom from (subselect) as foo' (couldnt find ' from
>>> More help: <br><br>
>>> Error with POSTGIS data variable. You specified 'SELECT the_geom
>>> FROM (SELECT the_geom AS the_geom, betrnr AS betrnr, jahr AS jahr, oid
>>> AS oid FROM user_polygon) AS foo USING UNIQUE oid
>> SRID=3D31467'.<br>
>>> <br><br>
>>> </ServiceException>
>>> </ServiceExceptionReport>
>>> The history of my helplessness from bottom to top. We've tried the
>>> SELECTS with capitals, repeated uses of 'USING' etc. wont work.
>>> DATA "SELECT the_geom FROM (SELECT the_geom AS the_geom, betrnr AS
>>> betrnr, jahr AS jahr, oid AS oid FROM user_polygon) AS foo USING
>>> UNIQUE
>>> user_polygon.oid USING SRID=3D31467"
>>> # DATA "the_geom FROM (SELECT the_geom AS the_geom, betrnr AS betrnr,
>>> jahr AS jahr, oid AS oid FROM user_polygon) AS foo USING UNIQUE oid
>>> USING SRID=3D31467"
>>> # DATA "SELECT the_geom FROM (SELECT the_geom AS the_geom, betrnr AS
>>> UNIQUE
>>> oid USING SRID=3D31467;"
>>> UNIQUE
>>> jahr AS jahr, oid AS oid FROM user_polygon) as foo using unique oid
>>> using SRID=3D31467"
>>> # DATA 'the_geom FROM (SELECT betrnr, jahr FROM user_polygon) AS foo
>>> USING UNIQUE SRID=3D31467'
>>> # DATA "the_geom FROM user_polygon"
>>> Best regards,
>>> Arnulf.
More information about the MapServer-users mailing list
