RES: [UMN_MAPSERVER-USERS] Creation of shapefiles (PHP)
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Fri Jan 21 10:05:47 PST 2005
Jorge,
I don't remember if I tried to create a shapefile using four lines (I
assume your lines are the 4 lines of a square).
But what I do is put all the points in one line and then add this line
to the shapefile.
The code to create the shapefile seems to be right.
Murilo
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Jorge Gaspar Sanz Salinas
Enviada em: sexta-feira, 21 de janeiro de 2005 15:15
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] Creation of shapefiles (PHP)
Matt Brown escribió:
> Jorge,
> I don't know if this is the problem, but you might try building one
line,
> instead of four, and make sure that the beginning and ending points
are the
> same. then add the line object to the shape object
> Matt
Well, the lines are working (I can create succesfully an arc shapefile)
and points are well (the same point object to start and to end). Thus, I
think I'm doing something wrong with the polygon creation.
Can someone post a simple shapefile PHP creation? I didn't found
anything in the mailing list or in the web.
Thanks,
Departamento de Ingeniería Cartográfica, Geodesia y Fotogrametría
Universidad Politécnica de Valencia
More information about the MapServer-users
