RES: [UMN_MAPSERVER-USERS] Creation of shapefiles (PHP)
(SOLVED)
Jorge Gaspar Sanz Salinas
xurxosanz at YAHOO.ES
Fri Jan 21 13:28:48 EST 2005
Murilo Lacerda Yoshida escribió:
> Jorge,
> I don't remember if I tried to create a shapefile using four lines (I
> assume your lines are the 4 lines of a square).
> But what I do is put all the points in one line and then add this line
> to the shapefile.
> The code to create the shapefile seems to be right.
You were perfectly correct, adding the four points to the same line works.
Thanks!
Departamento de Ingeniería Cartográfica, Geodesia y Fotogrametría
Universidad Politécnica de Valencia
