Example Maps
Ken Lord
kenlord at GMAIL.COM
Fri Jan 21 13:47:27 EST 2005
Hi Nicole,
Confirm that your image extents are set correctly, as well as your projections.
MapServer may be creating the map correctly ... but all the data may
just not be in the view if the extents and projections have errors.
Cheers,
Ken Lord
Vancouver BC
On Fri, 21 Jan 2005 18:58:44 +0100, joerg pfeiffer <superbla3000 at gmx.net> wrote:
> > I have corrected the Shape- and Imagepath to my installation.
> > Typically I receive only the frame which tells me that the map
> > was created with MapServer and a legend at the bottom.
> > But the map is missing.
> hello Nicole,
> so is mapserver running? Can you perform those simple tests, like
> calling the cgi from a browser?
> And if yes, has mapserver the right permissions to write to the temp
> image directory?....
> joerg
