Example Maps
Nicole Faust n_faust at INFORMATIK.UNI-KL.DE
Mon Jan 24 06:25:01 PST 2005
Hello Joerg,
> so is mapserver running? Can you perform those simple tests, like
> calling the cgi from a browser?
Mapserver is running. When I call the mapserver CGI program I get
the following message (as mentioned in the mapserver tutorial: "If
you invoke it as is you will get this familiar message"):
No query information to decode. QUERY_STRING is set, but empty.
> And if yes, has mapserver the right permissions to write to the temp
> image directory?....
I have checked the permissions and made the temp image directory
accessible for writing operations of the mapserver.
And I found a mistake in the .map file.
Now the mapserver should work fine - I hope.
But now I have an problem with mapscript:
I've created a '.php' file to verify that PHP
and PHP/Mapscript were installed properly
The file looks like:
    <HTML>
    <BODY>
    <?php
    if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
      dl("php_mapscript.dll");
    else
      dl("php_mapscript.so");
    phpinfo();
   </BODY>
   </HTML>
I get the following error message:
Warning: Function registration failed - duplicate name - ms_getversion in
/home/n_faust/software/projekt/htdocs/phpinfo_mapscript.phtml on line 21
Warning: Function registration failed - duplicate name - ms_newmapobj in
Warning: Function registration failed - duplicate name - ms_newlayerobj in
Warning: Function registration failed - duplicate name - ms_newclassobj in
Warning: Function registration failed - duplicate name - ms_newpointobj in
Warning: Function registration failed - duplicate name - ms_newlineobj in
Warning: Function registration failed - duplicate name - ms_newshapeobj in
ms_newshapefileobj in
Warning: Function registration failed - duplicate name - ms_newrectobj in
Warning: Function registration failed - duplicate name - ms_getcwd in
Warning: Function registration failed - duplicate name - ms_getpid in
Warning: Function registration failed - duplicate name - ms_getscale in
ms_newprojectionobj in
Warning: Function registration failed - duplicate name - ms_tokenizemap in
Warning: Function registration failed - duplicate name - ms_newstyleobj in
Warning: Function registration failed - duplicate name - ms_newgridobj in
Warning: Function registration failed - duplicate name - ms_geterrorobj in
Warning: Function registration failed - duplicate name - ms_reseterrorlist
in /home/n_faust/software/projekt/htdocs/phpinfo_mapscript.phtml on line
21
Warning: Function registration failed - duplicate name - ms_newsymbolobj
21
Warning: MapScript: Unable to register functions, unable to load in
Unknown on line 0
After the error messages the output of phpinfo() is displayed.
I set the extensions_dir in the php.ini file to
/home/n_faust/software/projekt/lib/php - where the file php_mapscript.so
is stored.
What is wrong?
Any suggestions?
Regards,
  Nicole Faust
PS: I had a look at
    http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html
    but the problem could not be solved.
More information about the MapServer-users mailing list
