Example Maps
Nicole Faust
n_faust at INFORMATIK.UNI-KL.DE
Mon Jan 24 09:46:45 EST 2005
Hello Hal,
> Did you mean to say the scalebar at the bottom? The legend is at the
> top, in this example.
Yes, I meant the scalebar, sorry I've confounded these to things.
> correct. My guess is that your path to the shapefile is not really
> what you think it is. This can happen in a virtual server
> environment (if your Apache is serving multiple domains from the same
> machine).
I adjusted the path in the .map file.
> You might also have a permissions problem--can the Apache process
> owner read the directory where the datafiles are?
I set the permissions of the directory so that the datafiles should now be
readable.
But when I try to display the map in my browser I get the
following error message:
mapserv(): Web application error. No template provided.
What went wrong?
Regards,
Nicole Faust
