netCDF in a mapfile
Frank Warmerdam fwarmerdam at GMAIL.COM
Fri Jan 21 12:47:15 PST 2005
On Thu, 20 Jan 2005 10:58:55 +0100, Tony Jolibois <tjolibois at cls.fr> wrote:
>            Hi all,
>  I try to display  netCDF file with the GDAL driver, but no succeed.
>  The gdalinfo give a good response, but I don't know how I can specifie my
> variable and the depth for the layer in the mapfile (it is a 3 dimension
> variable).
>  Can anyone help me ?
>  Thanks in advance,
>  Tony
>  gdal from CVS today
>  mapserver 4.4.1
>  on linux AS
>  gdalinfo :
>  Driver: netCDF/network Common Data Format
>  Size is 8, 129
Tony,
I doubt that the above is really a meaningful response
in this case.  I think GDAL is picking the wrong
dimension for x.  The netCDF driver also doesn't
handle multiple variables in one netCDF file gracefully.
As it happens, you are once again operating on the
frontier I am interested in advancing.  In particular,
I am interested in improving the netCDF driver.
Would you mind pointing me to the netCDF file
in question so I can try and use it as an example
while I work on the driver.
Best regards,
More information about the MapServer-users mailing list
