projection questions
Norman Vine
nhv at CAPE.COM
Mon Jan 24 15:35:58 EST 2005
Jeff Portwine writes:
> It is entirely possible that as you said i'm being misled by the Map Point
> map... and that I just have to get used to how this looks , but regardless I
> need to understand what's going on so that when the people I'm doing this
> for ask me I can explain the difference :)
< snip >
> I'm not actually using mappoint data to create the map, so I have no idea
> how they project the data when they generate maps... but I can't really
> seem to make my output look any different regardless of what I use for
> output projection.
Jeff
I suggest you spend a little time here
http://www.colorado.edu/geography/gcraft/notes/mapproj/mapproj_f.html
and some more experimenting with your mapfile
http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#projection
hint < folowing up on Ed's >
HTH
Norman
