raster file display error
Jose Luis Gonzalez
joseluismapserver at YAHOO.ES
Tue Jan 25 00:55:59 PST 2005
> Hi everyone.
> Lets see if someone can tell me what could be wrong.
> I am working with:
> MapServer version 4.4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
> INPUT=GDAL INPUT=SHAPEFILE
> I am using java servlets.
> when I use shapefiles :usa1.map it works but when I want to include a
> tif file it doesn't work: usa3.map, nitelti020l.tif
> The instructions I use are:
> for the first case that works:
> mapObj map = new mapObj("/mypath/usa1.map");
> imageObj img = map.draw();
> img.save("/mypath/usa1.png", map);
> out.println("<BR><IMG SRC=http://webbrowserpath/usa1.png>");
> For the second case with raster that doesn't work:
> mapObj map = new mapObj("/mypath/usa3.map");
> img.save("/mypath/usa3.png", map);
> out.println("<BR><IMG SRC=http://webbrowserpath/usa3.png>");
> And here are the mapfiles:
> usa1.map
> MAP
> NAME USA1
> STATUS ON
> SIZE 800 500
> IMAGETYPE PNG
> IMAGECOLOR 240 240 240
> SHAPEPATH "/mypath"
> EXTENT -8000000 300000 5000000 1500000
> UNITS METERS
> PROJECTION
> "proj=lcc" "lat_1=32" "lat_2=44" "lat_0=38" "lon_0=-100" "x_0=0"
> "y_0=0" "ellps=GRS80" "datum=NAD83"
> END
> WEB
> IMAGEPATH "/mypath/"
> IMAGEURL "/mypath/"
> END
> LAYER
> NAME "US state boundaries"
> TYPE POLYGON
> STATUS ON
> DATA "statesp020"
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> "datum=NAD83"
> END
> CLASS
> NAME "US states"
> OUTLINECOLOR 60 60 60
> COLOR 255 255 0
> SYMBOL 0
> END
> END
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 10 480
> END
> TEXT 'Made with Mapserver.'
> END
> CLASS
> LABEL
> TYPE BITMAP
> POSITION CR
> COLOR 0 0 0
> END
> END
> END
> END
> usa3.map
> MAP
> NAME USA3
> STATUS ON
> IMAGETYPE PNG
> SIZE 800 500
> SHAPEPATH "/mypath"
> EXTENT -6086744.000 -2784127 4278894 4485901
> UNITS METERS
> PROJECTION "proj=laea" "lat_0=45" "lon_0=-100" "ellps=GRS80"
> "datum=NAD83" END
> WEB
> IMAGEURL "/mypath/"
> END
> LAYER
> NAME "Nighttime lights"
> TYPE RASTER
> STATUS ON
> DATA "/mypath/nitelti020l.tif"
> END
> LAYER
> TYPE POLYGON
> STATUS ON
> DATA "statesp020"
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> "datum=NAD83"
> END
> CLASS
> NAME "US states"
> OUTLINECOLOR 50 50 50
> SYMBOL 0
> END
> END
> END
Jose Luis
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050125/21815e28/attachment.htm>
More information about the MapServer-users
