installation problems [was Re: Example Maps]
Nicole Faust
n_faust at INFORMATIK.UNI-KL.DE
Tue Jan 25 05:00:03 EST 2005
Hello Hal,
> I haven't seen the "Web application error. No template provided."
> message; I can't help with interpreting that. Anybody?
I've only forgotten the "&mode=map" in the URL while
I wanted to display the map.
> I am also baffled by the "duplicate name - ms_newmapobj in
> /home/n_faust/software/projekt/htdocs/phpinfo_mapscript.phtml on line
> 21" errors, since the code you posted appears to have only 15 lines.
The file that caused these errors was a test file - I added it to
the attachement (files.tar.gz).
> The devil is probably in the details. It would be helpful if you
> would post the unedited, exact text of the .MAP and .PHP files you're
> using, together with the URL that we could use to view the result.
> My hunch is still that you are having some sort of hiccup with a path.
The unedited .MAP and .PHP files
(from the site http://www.mobilegeographics.com/mapserver/)
can be found in files.tar.gz
My versions (where I tried to adjust the shape- and imagepath) can be
found in mod_files.tar.gz
The DocumentRoot of Apache is: /home/n_faust/software/projekt/htdocs.
karten is a subdirectory of the DocumentRoot where the .MAP, .PHP /
.PHTML, .SHP and .SHX files are stored.
You have only to adjust the name of the file you want to display in the
following URL:
http://rockster.informatik.uni-kl.de:8081/cgi-bin/mapserv?map=karten/usa2.map&mode=map
> Are you running in a virtual server environment? That is, are there
> multiple domains hosted on the machine you're using?
No, I'm not running a virtual server environment.
Regards,
Nicole
Type: application/x-gunzip
Desc:
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050125/fd18f49c/files.tar.bin
Desc:
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050125/fd18f49c/mod_files.tar.bin
