installation problems [was Re: Example Maps]
Nicole Faust
n_faust at INFORMATIK.UNI-KL.DE
Tue Jan 25 06:16:53 EST 2005
Hello,
> > The devil is probably in the details. It would be helpful if you
> > would post the unedited, exact text of the .MAP and .PHP files you're
> > using, together with the URL that we could use to view the result.
> > My hunch is still that you are having some sort of hiccup with a path.
> The unedited .MAP and .PHP files
> (from the site http://www.mobilegeographics.com/mapserver/)
> can be found in files.tar.gz
> My versions (where I tried to adjust the shape- and imagepath) can be
> found in mod_files.tar.gz
I made some tests and changed the path in the WEB section of the .MAP
file. I also commented out the second line in the .PHTML files.
Now I can display the images that are generated from the mapserver
integrated into the .PHTML file.
I think there's something wrong with the PHP/Mapscript installation or
configuration. But I don't know what. I followed the installation steps on
the site http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
section "Running only PHPMapScript scripts as a CGI".
But when I try to display the .MAP file directly (see URL below)
the image is still missing. Any ideas?
(I attached the edited files to this email.)
> The DocumentRoot of Apache is: /home/n_faust/software/projekt/htdocs.
> karten is a subdirectory of the DocumentRoot where the .MAP, .PHP /
> .PHTML, .SHP and .SHX files are stored.
> You have only to adjust the name of the file you want to display in the
> following URL:
> http://rockster.informatik.uni-kl.de:8081/cgi-bin/mapserv?map=karten/usa2.map&mode=map
Regards,
Nicole
Type: application/x-gunzip
Desc:
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050125/5c214f26/files-new.tar.bin
