projection woes
    Mark Adams
    markadams at CUESTASYS.COM
    Tue Jan 25 08:02:36 PST 2005
Hoping someone can help me out with problems Im having combining data from
different projections. I have a set of layers in NAD 27 zone 17, which Im
displaying with a PROJECTION object set at the MAP level
with "init=EPSG:26717". Im trying to add a layer that is in NAD 83 zone
17. If I simply add this layer without specifying a PROJECTION, it displays
fine, albeit out of sync with the underlying data due to the datum shift.
If I add a PROJECTION object to the LAYER set with "init=EPSG:26917", the
layer disappears  no error in the log file, just no data. The same thing
happens if I add a similar PROJECTION object to any other layer  the data
disappears.
Ive gone through the proj installation instructions, I cant see anything
wrong.
Any suggestions?
Thanks in advance.
- Mark Adams
markadams at cuestasys.com
More information about the MapServer-users
