[rosa-users] Rosa applet for mapserver
Palanisamy, Giri
palanisamyg at ORNL.GOV
Tue Jan 25 11:16:42 EST 2005
Great!, it worked thanks!
Giri
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Tuesday, January 25, 2005 11:11 AM
To: Palanisamy, Giri
Cc: rosa-users at lists.maptools.org
Subject: Re: [rosa-users] Rosa applet for mapserver
Palanisamy, Giri wrote:
> I have installed the GMap sample application in windows IIS server,
and
> I realized the GMap app is setup for apache server. The IIS server
could
> not recognize the "$HTTP_FORM_VARS()" function call, for example for
the
> following line of code (in gmap75inc.php)
> if ($HTTP_FORM_VARS["ViewRegion"])
> I am getting the following error:
> Notice: Undefined index: ViewRegion in
> f:\Inetpub\wwwroot\gmap\htdocs\gmap75.inc.php on line 275
> If I comment out all the lines that contains "$HTTP_FORM_VARS()" then
I
> am able to see the map.
> Do you know how I can handle this in IIS?
The problem is not specific to IIS: I think it must be because you have
E_NOTICE reporting enabled in your php.ini. The simple fix is to disable
notices using the following in php.ini:
error_reporting = E_ALL & ~E_NOTICE
The "right" fix would be to cleanup the GMap code to test if a given
array index exists before accessing it, e.g. change the if() statement
above to the following:
if (isset($HTTP_FORM_VARS["ViewRegion"]) &&
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
