Rosa Applet GMap
Palanisamy, Giri
palanisamyg at ORNL.GOV
Tue Jan 25 11:08:47 EST 2005
Thanks for the information, I have installed the GMap sample application
in windows IIS server, and I realized the GMap app is setup for apache
server. The IIS server could not recognize the "$HTTP_FORM_VARS()"
function call, for example for the following line of code (in
gmap75inc.php)
if ($HTTP_FORM_VARS["ViewRegion"])
I am getting the following error:
Notice: Undefined index: ViewRegion in
f:\Inetpub\wwwroot\gmap\htdocs\gmap75.inc.php on line 275
If I comment out all the lines that contains "$HTTP_FORM_VARS()" then I
am able to see the map.
There is a similar problem reported in
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0407/msg00115.h
tml
How do I handle this in IIS?
Thanks.
Giri
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Monday, January 24, 2005 5:34 PM
To: Palanisamy, Giri
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Rosa Applet
There is the GMap application that you can download
(http://dl.maptools.org/dl/gmap-ms40.zip). Although It is an old app, It
is using php mapscript and rosa.
You probably have seen the rosa docs at
(http://maptools.org/rosa/index.phtml) :
Later,
Palanisamy, Giri wrote:
> Hi,
> Is there a documentation available for php - rosa applet? Can anyone
> provide me a sample application that displayes an image using php/rosa
> applet which does some zoomin and zoomout functions?
> Thanks!
> Giri
> *From:* UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> *On Behalf Of *Constantin Cristian
> *Sent:* Monday, January 24, 2005 3:55 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] PHP Mapscript region selection
> I don't think you can do it with php only.
> That is an applet they are using but you can also do it with
JavaScript:
> http://www.inovagis.org/quickwms/
> ----- Original Message -----
> *From:* Palanisamy, Giri <mailto:palanisamyg at ORNL.GOV>
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> *Sent:* Monday, January 24, 2005 10:21 PM
> *Subject:* [UMN_MAPSERVER-USERS] PHP Mapscript region selection
> HI,
> I have just started exploring the PHP-mapscript, and got my basic
> mapserver demo working (display the image, zoom in, zoom out, and
> pan), Is there a way to select a region and zoom-in? instead of
> point click zoom? Do I need to have an applet for this?. Can
anyone
> give me a sample php code that does region selection?
> Here is an example that allows region selection
> http://www2.dmsolutions.on.ca/gmap/gmap75.phtml
> I guess this uses java applet.
> Thanks
> Giri
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
